volvo 740 gle
SA6
Posted 26 May 2004 - 09:02 AM
SA6
  • 1,570 posts
I had the same problem before when I first got my 740, the odometer that
indicate the speed is function but the trip for the mileage was not
functioning so I took off my meter and check for any defective, found out
the gear was worn so I changed it. It functioning until today.
I don't get what your previous owner was thinking, if he is a real ex FA
machanic, he should be much well verse with Volvo than DIY guy like me.
niaoniao
Posted 26 May 2004 - 08:20 PM
niaoniao
  • 21 posts
Dear SA6
I agree with you. will get him to check and change before I take delivery
tomorrow.
BTW, I visited the VOCM website and saw your car (the trip on 23MAY?).
Beautiful exterior. But didnt have anything on the interior. Care to
share some pictures? you can send to my email meeling65@hotmail.com.
niaoniao
Posted 29 May 2004 - 12:59 PM
niaoniao
  • 21 posts
Dear SA6
My brother, who is an enthusiast of DIY, told me that the shift between
gear 1 and 2 is not that smooth. He advises me to flush the automatic
transmission gear box. Does this help? Is it a complicated job and what
are other things that I should know or beware of before I send my new babe
to the workshop?
gkltsp
Posted 29 May 2004 - 03:43 PM
gkltsp
  • 1,108 posts
hi niao niao,
i had this problem too, you may try a flush or change the fluid and put in
some additives, otherwise, make sure u warm the car up completely before
you drive,... it should change.
FYi. to change to a re-cond auto gearbox... price whould be around RM2.5k
inclusive of workmanship and fluids .... but do this only as a last resort.
how are the other gears? try to use dexII auto oil ... Shell has it and
mobil has it too, coz about RM11 to RM13 per litre ...
hope it helps... you may want to gather a few more opinions...
cheers
SA6
Posted 31 May 2004 - 10:02 AM
SA6
  • 1,570 posts
niaoniao, a complete flush is good for your gearbox. First you should
identify the type of gearbox your car is having now. For 1989 and below
740 model auto gear box is most probabily equip with the ZF type while for
1990 and newer model are either AW70 or AW71 or AW71L. In my opinion, the
Aw is a better choice despite of the claim the ZF was bullet proof build.
THe AW was by Aishin-Warner, Aishin is a Japan maker who also build
gearbox for Toyota Supra, and the AW is serviceable and they even had
repair kit to overhaul it. Here in peninsular ther are several should who
do this work.
Mine auto gear box model is AW71L, I had it flush 4 times already before
full use of it. I had to do it becuase the original ATF was too damn
dirty. For your case my advise is to have ti flush by shop who got the
autogear flushing machine. They pump in new oil while the oil one were
runing out from the other pipe. If you do it yourself is a little messey.
niaoniao
Posted 05 June 2004 - 02:48 PM
niaoniao
  • 21 posts
Dear all
Help needed. The weatherstrip in the engine compartment which prevents
water from sipping through when running down from the windscreen is
missing (the rubber runs across the rear of engine compartment). A bit
worry since the distributor is just sitting at that spot. I have been
hunting around in Kuching but not available. Anyone can help?
BlueBrick
Posted 05 June 2004 - 06:48 PM
BlueBrick
  • 135 posts
SA6 thanks for the offer. I think i'll live with the dead odometer for now.
SA6
Posted 07 June 2004 - 08:45 AM
SA6
  • 1,570 posts
Try half cut shop, they should have it, otherwise find something that
similiar and glue it to the panel
VOL9833
Posted 14 June 2004 - 10:17 AM
VOL9833
  • 79 posts
Hi BlueBrick,
I recall i've done the odometer for my previous 740 for only rm 100++.
Like SA6 said, it just a worn small gear inside.I guess it's quite common
problem for 740. As for 940, till today so far so good.
SA6
Posted 15 June 2004 - 08:55 AM
SA6
  • 1,570 posts
Most of the RWD Volvo problem has a solution and it can be very simple to
fix too..Big Smile
