My 2009 BLM Auto. wad i've done to improve my ride
a) 15" rim 195/50/15
b)Gab lowered sport spring
c) use my preferred 10W-40 mineral engine oil
d) replace air filter with redline drop in
e) replace spark plugs with Denso IR
f) Exhaust 4-1 ,s-flow rear
g) replace stock cam gears with aerospeed adjustable
h) replace stock crank pulley with redline lightweight crank pully
i) installed redline front strut bar,UR lower front 4 point,lower rear 2 point & ARB
j) brek sys.Change top brek booster to double layer,bendix CT brek pad.
Now need u guys to recomend which brek cliper is most sutible for BLM.
BTW do any of u guys know/seen anybody mod their brek sys b4 for BLM.
Any sifu can help me on this.
no suggestion coz im still with standard brake system, no idea. standard feel less bite la.
since you have done quite extensively. dont mine if you can share experience of your mods.
mine not much.
i also using aerospeed but one on the intake side, 421 header and matola s-flow rear,
hurricane for suspension, also 15inchers 195/50.
got a few question from me,,
-how about the sound after changing sport filter. is it producing sporty sound since its drop in. how about high end?
-whats that double layer brake booster. is it extra vacuum tank?
-how much redline or ur strut bar, im looking for one
-how about bosch super 4, is it good or same.
if you care to share it will be great.
and sorry cant respond for the brake mod. im also looking for solution probably slotted/drilled disc.
may be others will jump in for suggestions.
