Let us have more feedback later on as it wears.....
Continental Comfort Contact CC5
Posted 16 June 2010 - 11:53 AM
Posted 16 June 2010 - 03:59 PM
Look quiet with fine pattern. Grooves quite wide for water clearance.....
looks like a better design than the cc1 woR
www.duragloss.com.my
Posted 16 June 2010 - 06:21 PM
CC5 looks good..wit wide longkang and aysm pattern
Posted 16 June 2010 - 06:48 PM
1) 205/60/R16 92H TL FR, speed index only H rating kah? That means the maximum speed safety zone is 210 kn/h only.What is the meaning TL FR?
2) 215/60/R16 98H XL TL, What is the meaning of XL TL?
Speed Rating Miles/Hour Kilometers/Hour
H 130 210
Also, for Michelin, 225/55/ZR16, what is the meaning of ZR16??
Also, I sent my car for alignment, the tyre sifu turned over my Primacy LC "outside" surface to inside, on the right front and left rear. The left front and right rear is normal, which the "outside" is facing outside. According to him, the car alignment is hopeless to do, following all "outside" facing outside. With his special turn over, the car could only be aligned. I asked, whether this would affect the traction in wet and dry. He told me, no matter how the tyre is turn over, it would still perform perfectly. Strange!!!! Then why should the tyre maker specify which side must face out???
May the bright sifu please advise
Posted 16 June 2010 - 06:49 PM
Yup, I agree looks better than CC1
Happen to be there. As I know, visuals helps a lot so take and post for the members......
Posted 16 June 2010 - 07:20 PM
H 130 210
TL FR is not commonly used. If not mistaken TL is tubeless. Cannot remember for FR. Sure it is not RF?
RF as in 225/55/RF16 will mean Runflats, and if 225/55/R16 RF is Reinforced.
XL is Extra Load. H Rating maximum speed in 210km/h
Any tyres with speed rating above V for 240km/h will have ZR. Your figure is not complete. Should be 225/55/ZR16 98W or something. Speed above V will have ZR and rating are W for 270 and Y for 300, Y(XL) for above 300.
The tyre shop who did your alignment should be shot if they flip Asymmetric tyres around. Even though may not have very great difference by they are built for a purpose. At extreme, the grip is not as good as when they are fitted correctly.
Posted 16 June 2010 - 11:46 PM
The Michelin 225/55/ZR16 95W. maximum speed 270.
The tyre marking for CC5 is FR.
http://www.conti-onl...-5,tabNr=1.html
Now considering CC5 or PS3. If not mistaken CC5 is comfort tyre. PS3 is UHP tyre. Not a fair comparison.....
Posted 17 June 2010 - 07:42 AM
FR stands for protection rib or rim protector:
http://www.conti-onl...en,tabNr=4.html
Posted 17 June 2010 - 01:53 PM
The tyre engineers in the R&D team has put in a lot of effort in designing tires, so outside means outside and inside means inside. Sometimes, the shop personnel try to be smart. If he has done so, suggest that you better get it corrected ASAP. Lucky these guys don't work for the airline change tyre department!
Posted 17 June 2010 - 02:35 PM
Apart from mixed up the inside and outside of tyres, I have also seen cars fitted with directional tyres fitted with the opposite rotation of the car travel direction. For sure these cars wiill have bad aquaplanning and are road hazard to other users especially in the wet condition.
