S40 Air Filter Replacment
Dinoboy
, Mar 02 2006 02:49 PM, 26 replies to this topic
Posted 02 March 2006 - 02:49 PM
I heard KIA's air filter is compatible with S40, could anyone advise which
exact model of KIA's air filter could be fixed in S40?
Can I transfer the K&N filter on KIA to S40?
Posted 02 March 2006 - 03:40 PM
Dinoboy
Is Kia Caren ( now Naza Citra ) and Spectra , actually the K&N air filter
for S40 & Kia are the same price...so not different.
Only if you compare oem filter for both s40 & Kia will be much
different on cost but again it will different on perfomance as well...
Posted 03 March 2006 - 09:45 AM
It is not easy to get K&N filter for S40, so can you confirm that I could
purchase the K&N filter on Kia Caren or Spectra for my S40 instead?
Posted 03 March 2006 - 10:33 AM
Dinoboy
i dunno why you said difficult to find s40 K&N air filter ....had seen
many shop stock it. try - SpeedWorks, Hokomotor, Rosedi,
Kakimotor....might want to try N1 Racing, Autobags and even Eneos
kepong...1u one no stock ...any how those K&N products at Eneos
are supplied by Speedworks.....if really can't find it then only go for kia.
Posted 06 March 2006 - 12:14 PM
Dinoboy
If from JB, there also have SpeedWorks outlet or you can try VIS Auto
Lab at permas Jaya..they might have one.
Had check on the K&N products code and confirmed the S40 & kia
caren are the same.
caren are the same.
Posted 06 March 2006 - 09:00 PM
Hi Richard,
I am looking for low end rev fuel saving with the K&N filter. However my
search found that K&N air filter is only best at high rev, I wonder it is
more wise-able to stick with the original Volvo filter, since the
filtration capability is much better than oil-based filter? I don't really
need more oomph at higher rev as it is already turbo charged.
Your view pls.
Your view pls.
Posted 13 March 2006 - 02:36 PM
Hi Richard,
Instead of spending the $ into K&N filter, I have decided to invest a
little bit more in the Stainless Steel Brakeline Kits.
Pls see URL below:
Pretty good deal.
Pls see URL below:
Pretty good deal.
Posted 13 March 2006 - 05:11 PM
Dinoboy
In Fact you can get local brand - Pro RS stainless steel brake hoses
with installation & flushing and new brake oil - DOT4 at around
rm 290 plus 2 years warranty , try log in they wedsite :
www.rosedi-autosports.com....and also if can get good perfomance
brake pads like EBC Green stuff ( front ) & Black stuff( rear ) with this
s/s brake hoses it will be perfect....
