ATF Change for S40
Posted 02 January 2005 - 05:01 PM
to change the ATF for life. I have some doubt about this. Can anyone
advise should I change the ATF regularly for S40 5-speed auto? What should
be the change interval? and can I just change half the capacity of the
fluid i.e. 4 litre will do?
I know that the ATF for Volvo 5-speed AT is very expensive!
Posted 02 January 2005 - 09:05 PM
you change your ATF on a regular basis...have a look at this link,it has
some Transmission Fluids FAQ
http://kaminski.iwarp.com/catalog.html
Posted 03 January 2005 - 08:49 AM
such thing as no need to change oil for life !!!??? check what type of ATF
uses in your S40 than change it lar. You will feel a smoother gear shift
once your ATF change, try it won't harm your car... "Volvo For Life"
not "No oil change for Life"...got it
Posted 03 January 2005 - 09:08 AM
yours is manual ?
Posted 03 January 2005 - 02:44 PM
never change it at all. S40 uses what transmission? ZF or AW?
Posted 07 January 2005 - 04:02 PM
speed AT uses synthetic blend ATF. Question is what is the change interval
for synthetic ATF (for half replacement 4litre & complete drain 8 litre)?
Posted 09 January 2005 - 03:20 PM
I am new comer on this forum,
How much the cost volvo synthetic ATF ?.
Posted 10 January 2005 - 05:32 PM
4 litre.
Posted 11 January 2005 - 08:11 PM
Thanks for your info.
Are you always using that ori ATF oil ?, seems that very costly.
Posted 14 January 2005 - 11:32 AM
cost of repair is just not worth it for using compatible products.
I just wonder what is the recommended ATF change interval (for half
replacement and full drain).
