Best Diesel in Malaysia
Posted 08 June 2006 - 03:07 PM
As the diesel quality in Malaysia are low grade.
No choice and not fair for Malaysian using diesel vehicle.
My question is,
which fuel company have better diesel quality?
( Relatively high grade among our low grade diesel )
a)Shell
b)Caltex
c)Petronas
d)Mobil
e)Projet
f)BHP
Thank you.
D4D Commonrail Turbo
Posted 11 June 2006 - 11:32 AM
From sources, in a nutshell, BP/BHP gets thier diesel from Singapore which
is at least euro 2 compliant (<500ppm). Recently, thier govt has stipulated
to go lower (50ppm). So in this sense, BP diesel is the 'cleanest' and the
best you could say.
Posted 11 June 2006 - 11:17 PM
Dunno which is best, as there are differing views .
I use mainly Esso/Mobil sometimes Petronas and Caltex.
Performance seems to be the same. with some smoke from all.
Posted 12 June 2006 - 09:40 AM
Why dont you give BP a try and let me know what you think....cheers.
Posted 12 June 2006 - 09:46 AM
Posted 13 June 2006 - 11:33 AM
sulphur levels and possibly black smoke. But to be fair, its best to try
a few and compare, namely Petronas, BP and Projet.
Posted 13 June 2006 - 11:51 AM
and deteriorates
Posted 13 June 2006 - 12:21 PM
engine running is very much different, so much of torque, but lower speed.
I can't feel which diesel is more or less power. There was many yrs ago.
So new diesel kaki need a little time to get used to driving diesel. Then u
may tell which is good. Same brand of oil, can feel different varies fr
station to station.
D4D u getting Vigo?
Posted 14 June 2006 - 10:43 AM
Hi,911...
yes,i will get Vigo soon.
As Commonrail fuel injection system need the cleaner/higer grade of
diesel to produce substantially higher pressure and inject much more
finer fuel for improve combustion efficiency.
Dirty/ low grade diesel will make the fuel injector 'jam'.
I heard that maintenance cost for commonrail Injection system is quite
high.
so,better choose the good diesel instead.
Posted 14 June 2006 - 01:03 PM
personally, i use project diesel, seems like project give my citroen 1.9D
more power, second choice is BP. these are the 2 brand i trust.
My previous owner also recommend project.
i have try esso before but not good, no power compare to project/bp.
Also to share the caltex delo 400 is a good engine oil, just changed and
found out that my little cit love it very much & the engine temp. also
good.
