Savvy Engine Oil Options
Posted 21 August 2005 - 02:56 PM
Started this new tread for the benefit of new Savvy owners who might want
to know what brand of oil with the minimum recommended SAE 10W-30 that’s
available. Since the W rating applies to freezing temp & the second value
to boiling temp, its best to select oils based on the 2nd value instead.
On my end found the following:
Fully Synthetic:
1. Mobil 1 (10W-30, 5W-30, 0W-30)
2. Chemlube Premium Gold (10W-30)
3. Petronas Syntium 5000 SM (0W-30)
Semi-Synthetic:
1. Caltex Havoline Formula (10W-30)
2. Petronas Syntium 800 SL (10W-30)
3. Caltex Havoline Energy (5W-30)
4. Esso Ultra (5W-30)
Mineral:
1. Petronas Mach 5 SL (10W-30)
I think for cost/performance reasons, most Savvy owners will go with Semi-
Synthetic.
Posted 21 August 2005 - 05:15 PM
where can i get Chemlube Premium Gold (10W-30)??
how much for 4L?
Posted 21 August 2005 - 06:31 PM
Thanks for your informative subject on oil for Savvy. Should have posted
earlier as i have just serviced my Savvy on Saturday.
I used Petronas Syntium 1000SL 15W/50, the SC didn't have the Syntium 5000
SM (0/30W).
But i think due to our hot and humid weather conditions, oil with /50
would be better. Even though the manual specified as minimum /30, i think
its for european whether. Anyway its just my opinion.
Bye for now
Posted 21 August 2005 - 10:13 PM
lubricants. So what did the service center recommend on your first
service?
Posted 22 August 2005 - 01:59 AM
Sorry for the delayed post but i'm sure you're still gonna change oil when
the 2nd service is up. Anyway there are still many new owners out there
thats gonna get their Savvy soon. Hopefully this will help them decide.
Cheers!
Posted 22 August 2005 - 09:37 AM
Original Post : Tobyboy,
Fully syn oil will not water down (thin) in the heat. So the SAE specs
should be right.
Posted 23 August 2005 - 02:41 PM
which is not recommended.
i thought savvy recommended oil is SAE 30? suitable range of oil are
0W - 30, 5W - 30 and 10W - 30.
15W is too thick from my humble opinion
Posted 23 August 2005 - 03:58 PM
The problem was that during the time when i was servicing my Savvy, the SC
didn't have the 10w/30 based oil.
Posted 24 August 2005 - 03:45 AM
The SC can't cope with the high no. of car. Now most cars serviced at 10K
interval.
For good engine protection, extended drain and avoiding sludge build up.
A full synthetic is a must.
Posted 24 August 2005 - 08:56 AM
Actually, i'm a bit blur on the oil grade issues. In your opinion what
would be the optimum engine oil grade for a car like Savvy ?
