Toothbrush And Wheel Rims
cbsteh
Posted 19 January 2014 - 06:38 PM
cbsteh
  • 1,531 posts
Does anyone here uses a toothbrush to clean your wheel rims? I notice toothbrushes do a more thorough cleaning job than those wheel brushes.
2420l
Posted 19 January 2014 - 06:46 PM
2420l
  • 631 posts
QUOTE (cbsteh @ Jan 19 2014, 06:38 PM) <{POST_SNAPBACK}>
me too...this for sure la bro coz toothbrush is more hard than cleaning brush
cbsteh
Posted 19 January 2014 - 06:52 PM
cbsteh
  • 1,531 posts
QUOTE (2420l @ Jan 19 2014, 06:46 PM) <{POST_SNAPBACK}>
Toothbrushes are smaller too. I suppose I got programmed into using wheel brushes because wheel brushes are sold and even showed in videos. Toothbrushes instead do a better and more thorough job.
jonlsl
Posted 19 January 2014 - 11:11 PM
jonlsl
  • 2,013 posts
Yah, use kids toothbrush so that its small and flat enough to fit into the lugnut hole underneath the nut.
Posted 20 January 2014 - 10:05 AM
  • 71,856 posts
jklow123
Posted 20 January 2014 - 10:49 AM
jklow123
  • 147 posts
[quote name='cbsteh' date='Jan 19 2014, 06:38 PM' post='1863115']
[/quote
Buy the HARD ones with flexible neck. They work great and wont scratch the surface, while the flexible neck relieves extra pressure and is more manouverable in tight spots.
If you want the softest tbrush for the most delicate cleaning...Colgate's Sensitive Toothbrush with ultra soft and superfine bristles closely packed, with each bristle having a rounded (not sharp) tip.
Posted 20 January 2014 - 12:43 PM
  • 71,856 posts
QUOTE (jklow123 @ Jan 20 2014, 10:49 AM) <{POST_SNAPBACK}>
CoffeeDude
Posted 20 January 2014 - 01:07 PM
CoffeeDude
  • 3,160 posts
cbsteh
Posted 20 January 2014 - 01:13 PM
cbsteh
  • 1,531 posts
Kakakaka. I can imagine rows of toothbrushes at the car aisle/section at hardware stores -- for brushing wheel rims not human teeth.
g88
Posted 20 January 2014 - 01:30 PM
g88
    Duke of Hazzard
  • PipPipPipPipPipPipPip
  • 48,280 posts
which part of the rim u using toothbrush to clean ? I found that Mothers Wheel Brush is generally good and gentle (soft) for rim surface.
For inner side of the rim, baby bottle brush would be good
