Hi Bro, Please order for me :-
1. Engine Oil Packagei.
Engine Oil Titan HPE Ultra 15W40 - 18 litre pack (sufficient for 2 change interval) - $240
ii. Bosh Oil Filter - 2X (sufficient for 2 change interval) - $20/piece X 2 = $40.
If the
HID lights or the
LED Blubs for Head lamb / fog lights and Reading light (front driver & Passenger)ada, please order that for me as well too.
one small (maybe big) issue... i cant make it this Sat to collect the stuff... would any Penang Kia be going ... who can ever so kindly collect these items for me please... or even at least until Ipoh please... then i can get my buddy who lives there to sent it over to me...
Please Message me the payment mode/ details please ill bank in tonight...
thanks a bunch!
Order & Payment Deadline - 02 April 2012
Order Collection - 07 April 2012
i. Engine Oil Titan HPE Ultra 15W40 - 18 litre pack (sufficient for 2 change interval) - $240
Recommended change interval - 5,000km ~ 7,500km depending on drive condition.
2. ATF Oil Package
i. ATF Oil FUCHS Titan 3353 (as specified in spec)
- 5 litre/container (sufficient for 1 drain-off) - $250
- 2 X 5 litre/bottle (If full flushing, require 9.5 litre) - $500
ii. Mayle Germany ATF Filter with Gasket - 1pcs - $100
Recommended change interval - 40,000~60,000 km depending on drive condition.
3. OEM Hyunkai Absorbers (Front & Rear) - RM100 each X 4 = RM400
4. Bendix 4WD Brake Pad (Front & Rear) - RM290
5. Rear Shock Stopper - RM75/each = RM150
6. Upper Arm Bush (2pcs left & 2pcs right) - $30/pc X 4pcs = $120
7. Lower Arm Bush (4pcs left & 4pcs right) - $30/pc X 8pcs = $240
8. Transmission Mounting - $130
9. 1 set Engine Mounting (2pcs) - $130 X 2 = $260
10. Vacuum Modulator - RM250 each X 2 = RM500
11. OEM Vemo Coupling Fan Clutch = RM250
12. Coolant Sensor - $75
13. Air Filter (OEM - Made in Korea) - RM60
14. Diesel Filter (OEM - Made in Korea) - RM180
15. Water Seperator (OEM - Made in Korea) - RM250
16. Bendix 4WD Brake Pad (Front & Rear) - RM290
17. Contitech Fan Belt (2257) from Germany - RM80
18. Aircon Cabin Filter (Korea OEM) - RM50 / piece
19. Crank POS Sensor Sensor - RM150
20. Cam Sensor - RM170
21. Tie Rod & Rod End - RM190 / set X 2 side = RM380
22. Tailgate Gas Struts Lifter (Window) - Local brand = RM90 / piece
23. Gas Struts Lifter (front bonnet) - Genuine Original = RM 130
24. Power Window Motor = RM190
25. Rear Brake Shoe - Original = RM 450 / set of left and right
26. Glow Plug - Original - RM90 per piece
27. Thermostat & Gasket - RM130 / set
28. Front Brake Disc (Left & Right) Original - RM650/set
29. Rear Brake Disc (Left & Right) Original - RM600/set
Order List
1. r3xt0n - RM280
2. 2-zull1101 - RM1,590 - PAID
2. 2. ATF Oil Package
- 5 litre/container (sufficient for 1 drain-off) = RM 250
ii. Mayle Germany ATF Filter with Gasket - 1pcs - = RM 100
3. OEM Hyunkai Absorbers (Front & Rear) - RM100 each X 4 = RM 400
5. Rear Shock Stopper - RM75/each = RM 150
14. Diesel Filter (OEM - Made in Korea) = RM 180
21. Tie Rod & Rod End - RM190 / set X 2 side = RM 380
3. Allan69 - RM1,350 - PAID
2. Mayle Germany ATF Filter with Gasket - 1pcs - = RM 100
Item# 4. Bendix 4WD Brake Pad (Front & Rear) - RM290
Item# 14. Diesel Filter (OEM - Made in Korea) - RM180
Item# 18. Aircon Cabin Filter (Korea OEM) - RM50 / piece (2x) = RM100
Item# 19. Crank POS Sensor - RM150
Item# 20. Cam Sensor - RM170
Turbo Vacuum Hose - RM80
4. Phoong - RM880 - PAID
2. ATF Oil Package
5. Penapis - RM390
18. Aircon Cabin Filter (Korea OEM) - RM50 / piece X 2 = RM100
6. Neonlee - RM280
Total Order = RM4,490
Order Paid = RM3,820
Bros who wish to make their order, please post your list here and payment instruction will be PM to you.
