QUOTE (r3xt0n @ Mar 24 2012, 12:38 AM) <{POST_SNAPBACK}>
Order & Payment Deadline - CLOSED
Order Collection - 07 April 2012
1. Engine Oil Package
i. Engine Oil Titan HPE Ultra 15W40 - 18 litre pack (sufficient for 2 change interval) - $240
ii. Bosh Oil Filter - 2X (sufficient for 2 change interval) - $20/piece X 2 = $40.
Recommended change interval - 5,000km ~ 7,500km depending on drive condition.
2. ATF Oil Package
i. ATF Oil FUCHS Titan 3353 (as specified in spec)
- 5 litre/container (sufficient for 1 drain-off) - $250
- 2 X 5 litre/bottle (If full flushing, require 9.5 litre) - $500
ii. Mayle Germany ATF Filter with Gasket - 1pcs - $100
Recommended change interval - 40,000~60,000 km depending on drive condition.
3. OEM Hyunkai Absorbers (Front & Rear) - RM100 each X 4 = RM400
4. Bendix 4WD Brake Pad (Front & Rear) - RM290
5. Rear Shock Stopper - RM75/each = RM150
6. Upper Arm Bush (2pcs left & 2pcs right) - $30/pc X 4pcs = $120
7. Lower Arm Bush (4pcs left & 4pcs right) - $30/pc X 8pcs = $240
8. Transmission Mounting - $130
9. 1 set Engine Mounting (2pcs) - $130 X 2 = $260
10. Vacuum Modulator - RM250 each X 2 = RM500
11. OEM Vemo Coupling Fan Clutch = RM250
12. Coolant Sensor - $75
13. Air Filter (OEM - Made in Korea) - RM60
14. Diesel Filter (OEM - Made in Korea) - RM180
15. Water Seperator (OEM - Made in Korea) - RM250
16. Bendix 4WD Brake Pad (Front & Rear) - RM290
17. Contitech Fan Belt (2257) from Germany - RM80
18. Aircon Cabin Filter (Korea OEM) - RM50 / piece
19. Crank POS Sensor Sensor - RM150
20. Cam Sensor - RM170
21. Tie Rod & Rod End - RM190 / set X 2 side = RM380
22. Tailgate Gas Struts Lifter (Window) - Local brand = RM90 / piece
23. Gas Struts Lifter (front bonnet) - Genuine Original = RM 130
24. Power Window Motor = RM190
25. Rear Brake Shoe - Original = RM 450 / set of left and right
26. Glow Plug - Original - RM90 per piece
27. Thermostat & Gasket - RM130 / set
28. Front Brake Disc (Left & Right) Original - RM650/set
29. Rear Brake Disc (Left & Right) Original - RM600/set
Order List
3. Allan69 - RM1,350 - PAID
2. Mayle Germany ATF Filter with Gasket - 1pcs - = RM 100
Item# 4. Bendix 4WD Brake Pad (Front & Rear) - RM290
Item# 14. Diesel Filter (OEM - Made in Korea) - RM180
Item# 18. Aircon Cabin Filter (Korea OEM) - RM50 / piece (2x) = RM100
Item# 19. Crank POS Sensor - RM150
Item# 20. Cam Sensor - RM170
Turbo Vacuum Hose - RM80
Bros who wish to make their order, please post your list here and payment instruction will be PM to you.
2. ATF Oil Package
Order List
I am very happy with the braking efficeincy of the just installed Bendix 4WD Brake Pad (Front & Rear) . Thanks Bro Wilson for a good recommendation.
