April 2012 Group Order
Posted 24 March 2012 - 12:38 AM
Order Collection - 07 April 2012
1. Engine Oil Package
i. Engine Oil Titan HPE Ultra 15W40 - 18 litre pack (sufficient for 2 change interval) - $240
ii. Bosh Oil Filter - 2X (sufficient for 2 change interval) - $20/piece X 2 = $40.
Recommended change interval - 5,000km ~ 7,500km depending on drive condition.
2. ATF Oil Package
i. ATF Oil FUCHS Titan 3353 (as specified in spec)
- 5 litre/container (sufficient for 1 drain-off) - $250
- 2 X 5 litre/bottle (If full flushing, require 9.5 litre) - $500
ii. Mayle Germany ATF Filter with Gasket - 1pcs - $100
Recommended change interval - 40,000~60,000 km depending on drive condition.
3. OEM Hyunkai Absorbers (Front & Rear) - RM100 each X 4 = RM400
4. Bendix 4WD Brake Pad (Front & Rear) - RM290
5. Rear Shock Stopper - RM75/each = RM150
6. Upper Arm Bush (2pcs left & 2pcs right) - $30/pc X 4pcs = $120
7. Lower Arm Bush (4pcs left & 4pcs right) - $30/pc X 8pcs = $240
8. Transmission Mounting - $130
9. 1 set Engine Mounting (2pcs) - $130 X 2 = $260
10. Vacuum Modulator - RM250 each X 2 = RM500
11. OEM Vemo Coupling Fan Clutch = RM250
12. Coolant Sensor - $75
13. Air Filter (OEM - Made in Korea) - RM60
14. Diesel Filter (OEM - Made in Korea) - RM180
15. Water Seperator (OEM - Made in Korea) - RM250
16. Bendix 4WD Brake Pad (Front & Rear) - RM290
17. Contitech Fan Belt (2257) from Germany - RM80
18. Aircon Cabin Filter (Korea OEM) - RM50 / piece
19. Crank POS Sensor Sensor - RM150
20. Cam Sensor - RM170
21. Tie Rod & Rod End - RM190 / set X 2 side = RM380
22. Tailgate Gas Struts Lifter (Window) - Local brand = RM90 / piece
23. Gas Struts Lifter (front bonnet) - Genuine Original = RM 130
24. Power Window Motor = RM190
25. Rear Brake Shoe - Original = RM 450 / set of left and right
26. Glow Plug - Original - RM90 per piece
27. Thermostat & Gasket - RM130 / set
28. Front Brake Disc (Left & Right) Original - RM650/set
29. Rear Brake Disc (Left & Right) Original - RM600/set
Order List
1. r3xt0n - RM280
2. 2-zull1101 - RM1,590 - PAID
2. 2. ATF Oil Package
- 5 litre/container (sufficient for 1 drain-off) = RM 250
ii. Mayle Germany ATF Filter with Gasket - 1pcs - = RM 100
3. OEM Hyunkai Absorbers (Front & Rear) - RM100 each X 4 = RM 400
5. Rear Shock Stopper - RM75/each = RM 150
14. Diesel Filter (OEM - Made in Korea) = RM 180
21. Tie Rod & Rod End - RM190 / set X 2 side = RM 380
3. Allan69 - RM1,350 - PAID
2. Mayle Germany ATF Filter with Gasket - 1pcs - = RM 100
Item# 4. Bendix 4WD Brake Pad (Front & Rear) - RM290
Item# 14. Diesel Filter (OEM - Made in Korea) - RM180
Item# 18. Aircon Cabin Filter (Korea OEM) - RM50 / piece (2x) = RM100
Item# 19. Crank POS Sensor - RM150
Item# 20. Cam Sensor - RM170
Turbo Vacuum Hose - RM80
4. Phoong - RM880 - PAID
2. ATF Oil Package
5. Penapis - RM100
18. Aircon Cabin Filter (Korea OEM) - RM50 / piece X 2 = RM100
6. Neonlee - RM280
7. lu18 - RM280 - PAID RM280
8. rex6680 - RM280
9. blackrex - RM280 - PAID
10. Mckhairie = RM360
11. WLU9998 - RM170
Total Order = RM5,570
Order Paid = RM4,380
Bros who wish to make their order, please post your list here and payment instruction will be PM to you.
Posted 24 March 2012 - 11:32 AM
2. ATF Oil Package
Order List
1. r3xt0n - RM280
2.
3.
4.
5.
Total Order =
Order Paid =
Hi bro,
Thought of getting items 1 (Engine oil) & 2 (ATF oil package), but can I ask where you do ATF oil flushing? Reasonable charges? Normally go to USJ. Thanks for info.
Regards,
phoong
Posted 24 March 2012 - 11:53 AM
2-zull1101
Total Order = RM1590
Order Paid = pls quote me together with courier charge to Terengganu,tq
Posted 24 March 2012 - 05:06 PM
Regards,
phoong
USJ should have the machine to do ATF flushing. In Ipoh workshop, they charge RM30 for ATF Flushing, perhaps KL slightly more.
Posted 24 March 2012 - 05:11 PM
It is going to be quite a bulky consignment with 5 litre ATF Oil & 4 Hyunkai Absorbers. Any chance you visiting KL/PJ/PG/Ipoh/Melaka soon?
Posted 24 March 2012 - 05:28 PM
paiseh lah......USJ quoted me rm180 for flushing.
Posted 25 March 2012 - 03:38 AM
Opphh...5 liters of ATF and 2 pair of shocks...haiyaa..I forgotlah about the weight ..thanks for the notification.
ok..I'll ask my friend who stay in Batu Caves to pick up the orders somewhere in KL once the items ready...
just PM me a contact number then I'll ask him to get it...thanks
Posted 25 March 2012 - 11:33 PM
2. ATF Oil Package
Order List
1. r3xt0n - RM280
2.
3.
4.
5.
Total Order =
Order Paid =
Bro, for the ATF Oil Package, can I buy item# ii. Mayle Germany ATF Filter with Gasket - 1pc - $100 (I assumed this is MYR or RM) only? Reason being I have booked my ATF from 3rd party in Penang. Secondly, are we able to source for Drop- in K&N Filter? Thank you.
Posted 26 March 2012 - 02:24 AM
Right, the courier fees will not be cheap, so may not worth the saving. Will add your order and send you the payment instruction.
Posted 26 March 2012 - 02:26 AM
Will add your order and PM you the payment instruction.
The last piece stock is reserved by Bro Greydevil but still waiting for his payment confirmation. If not, can let you have it. KakiMotor is selling more than RM300.
