How's Your Sentra After Xx Yrs.?
yapvc
Posted 12 September 2014 - 02:27 PM
yapvc
  • 774 posts
QUOTE (samuione @ Sep 11 2014, 01:31 PM) <{POST_SNAPBACK}>
I send to workshop nearby, the workshop send to wiring checking, end up is wiring problem.
the workshop din't know what wire man did too.
so no able to share to problem here too.
It makes sense to wiring issue....it could be signal cables to one of the sensors either MAF sensor, IACV sensor, Injectors, or even the Post & Phase sensors.
You should ask the actual root cause. At least you know what's gone wrong, just my idea.
 "" Reduce speed, Manage anger & attitude - Arrive Alive ""
#122
samuione
Posted 03 June 2015 - 11:10 AM
samuione
  • 135 posts
Recently, my manual B14 found no pickup. Be able to to see the RPM drop while moving up to flyover or small hill, while accelerate car doesn’t move.
Clutch was replace, flywheel checked, fuel filter replace, than the problem still exist,
Seeks Sifu here able to advise?
#123
tyw2350
Posted 25 December 2015 - 11:57 PM
tyw2350
hello!! mine is also a nissan b14 year 94 auto with 300k km , do you still have the same problem right now?or if fixed already, please share on how u managed to do it, thanks
my problem with the car is that no matter how many alignments i have done on it , it still eat away the inner side of the tires on the front , (so i have to rotate every 5000km to get some good all around wear)
but other than that, it still runs like a crazy old demon wanting to fly*maybe*
it may be a 21yr old car, i still use 5w30 oil in it eventho every mechanics are telling me not to
maybe your using too thick of an oil for your car?or that it need some good cleaning inside the throttle body and engine
you might want to check this guy out for his products and services
https://forum.lowyat.net/topic/1300861
his name is elton
#124
Posted 27 December 2015 - 11:39 AM
  • 71,852 posts
What did the tyre shop personnel say on your alignment issues?
If wearing off on the inner shoulder on both sides then probably alignment issue. Too much toe out. If wearing only on one side inner shoulder then can be camber issue.
#125
samuione
Posted 17 January 2017 - 08:14 AM
samuione
  • 135 posts
is anyone still with yr B14 here ?
mine still with the B14 manual 95.
