Do You Heel 'n Toe?
jonlsl
Posted 15 June 2012 - 10:59 AM
jonlsl
  • 2,013 posts
QUOTE (mosh @ Jun 15 2012, 10:53 AM) <{POST_SNAPBACK}>
So that means you should be always doing:
1. Full throttle quick flat upshift.
i wonder did anyone notice I actualy wrote
1. Full throttle quick flat upshit vs. 1. Full throttle quick flat upshift. i went and corrected. hahahaha
#52
alldisc
Posted 15 June 2012 - 11:29 AM
alldisc
  • 2,705 posts
i cant heel and toe. definitely not for motorbikes where the clutch is hand operated. sterb292.gif
#53
jonlsl
Posted 15 June 2012 - 11:35 AM
jonlsl
  • 2,013 posts
QUOTE (alldisc @ Jun 15 2012, 11:29 AM) <{POST_SNAPBACK}>
But you still can do: hahahahaha
2. Brake-Blip-Downshift
3. Blip-downshift-accelleration
4. Blip-downshift-decelleration
Extra.
1. Full throttle quick flat upshift. (Best done with Dynojet Power commander and fuel cut quik shift)
2. Full throttle-closed throttle quick upshift.
3. Clutchless shift. (Best done with Dynojet Power commander and fuel cut quik shift)
5. Smooth upshift with out slipping clutch.
#54
alldisc
Posted 15 June 2012 - 11:51 AM
alldisc
  • 2,705 posts
QUOTE (jonlsl @ Jun 15 2012, 11:35 AM) <{POST_SNAPBACK}>
Extra.
hell yeah!.. that and some more.
#55
jklow123
Posted 24 January 2014 - 01:21 PM
jklow123
  • 147 posts
For normal daily street driving on automatic trans + FWD, i prefer to learn Left-Foot Braking.
Imo, its more applicable to today's more powerful cars, especially when you're cornering fast (but not like a maniac on public roads) where lifting the throttle momentarily at high speeds can cause the tail to step out.
Hence, LFB is also a safety technique. After 1yr of constant practice, i now brake with left feet all the time and you feel you've more control just before entering that tight corner. It became second nature....just like riding a bicycle, and teaching the brutal left feet to be as sensitive as the right feet.
#56
Posted 25 January 2014 - 02:45 PM
  • 71,817 posts
Later on won't know how to drive manual anymore..... smile_big.gif smile_big.gif
#57
jonlsl
Posted 25 January 2014 - 09:14 PM
jonlsl
  • 2,013 posts
QUOTE (vr2turbo @ Jan 25 2014, 02:45 PM) <{POST_SNAPBACK}>
i HEEL & TOE all the time when I drive a manual as its 2nd nature. You also need to learn how to downshift bilp on acceleration when you need power. Contrary to normal believe heel & toe is not for spirited driving only, its for every time you drive at any speed.
You need to learn how to brake downshift blip when certain cars not ergonomic for you to heel and toe. E.g. pedal height not properly adjusted, either too high or too low.
For me I only left foot brake on auto in very selected circumstances as most of the time my driving style is to make sure I finish my braking and downshifting in a straight line b4 pointing the nose of the car at the apex, so as to not unsettle the rear of the car. Very important especially when you driving a high HP RWD car especially in the wet. But on a FWD left foot brake all you want going into to the corner and even out of the corner to act as an LSD so as not to spin up the inside wheel too much on exit.
#58
jklow123
Posted 26 January 2014 - 09:09 AM
jklow123
  • 147 posts
QUOTE (jonlsl @ Jan 25 2014, 09:14 PM) <{POST_SNAPBACK}>
Oh yeah...mmmm...superbly said👍
