New Waja Radiator
Posted 10 January 2011 - 01:13 PM
  • 71,858 posts
QUOTE (kohf1drive @ Jan 9 2011, 04:34 PM) <{POST_SNAPBACK}>
Oil Base??
QUOTE (ndrifter @ Jan 9 2011, 05:33 PM) <{POST_SNAPBACK}>
my signature got, but wat is your recommendation ?
You put at the end, did not see it....ha! ha!
Castrol Premix, if okay with you just continue using. No need to change, just that some are using cap ayam brand, then will recommend not to use. Most recommend Toyota or Caltex coolant..... smile_tongue.gif
ndrifter
Posted 10 January 2011 - 01:35 PM
ndrifter
    NMT Newscaster
  • 2,353 posts
QUOTE (vr2turbo @ Jan 10 2011, 01:13 PM) <{POST_SNAPBACK}>
toyota / caltex coolant good? wat the rating?
pre-mix coolant also?
~~> 4g18 | '03 | 225K mileage and counting
APEXI | BOSCH | CASTROL | CE28N | DAYCO | EIBACH | FGK FUJITSUBO | HID | K&N | MITSUBISHI | NEXEN | STEELMATE | ULTRA RACING | WEGRO | WORKS ENGINEERING
Posted 10 January 2011 - 01:43 PM
  • 71,858 posts
QUOTE (ndrifter @ Jan 10 2011, 01:35 PM) <{POST_SNAPBACK}>
Never really put them to test, but as normal coolant better than those cap ayam brand of course. But of you are already using branded, as mentioned no need to change.
If want good, then Motul and I think Lubeguard coolant, but they cost a bomb...... smile_blackeye.gif
ndrifter
Posted 10 January 2011 - 02:24 PM
ndrifter
    NMT Newscaster
  • 2,353 posts
QUOTE (vr2turbo @ Jan 10 2011, 01:43 PM) <{POST_SNAPBACK}>
i cant afford Motul yet, haha @@
vy expensive, and pricing is per liter sale
Posted 10 January 2011 - 02:31 PM
  • 71,858 posts
QUOTE (ndrifter @ Jan 10 2011, 02:24 PM) <{POST_SNAPBACK}>
ndrifter
Posted 10 January 2011 - 02:51 PM
ndrifter
    NMT Newscaster
  • 2,353 posts
QUOTE (vr2turbo @ Jan 10 2011, 02:31 PM) <{POST_SNAPBACK}>
avionics
Posted 05 February 2014 - 03:41 PM
avionics
  • 376 posts
hi sifu,
my car seems that the big fan doesn't move 1,cud it be the temp not hot enough?using denso
Hai m so naive.
Posted 06 February 2014 - 08:37 AM
  • 71,858 posts
QUOTE (avionics @ Feb 5 2014, 03:41 PM) <{POST_SNAPBACK}>
hi sifu,
Let your engine reach operating temperature and if fan still don't turn better get it checked....
youfa77
Posted 18 February 2014 - 11:38 PM
youfa77
  • 1,246 posts
if the fan is not jam, then it could be the temperature switch (sensor)
When the sun go down, another world awakes....
