ndrifter
Posted 06 January 2011 - 12:00 PM
Yes, Car manufacturer already calculated for normal use.
Unless you are modding for Race, then many things to upgrade.....
You will notice the radiator fan going on and off (without air con). When on means hot and needs to be cooled, and when off means coolant within heat limit.
With air con on, most radiator fan are override to cool the air con also.....
thanks for precious input again
~~> 4g18 | '03 | 225K mileage and counting
Posted 06 January 2011 - 01:22 PM
you are welcome.........
ndrifter
Posted 06 January 2011 - 01:37 PM
haha my radiator also 8 years old adi,
any risk to continue use it?
so far still running fine
Posted 06 January 2011 - 04:12 PM
My philosophy is, when nothing is wrong, don't touch it.........
Check your hoses, especially the top one, because that is the return hose from engine to radiator and that carries very hot coolant. The lower hose is from radiator to engine and carries cooled coolant. If hoses have hardened then change them.
For radiator, as long as no leaks, leave it alone.
Change your radiator water and add coolant yearly or every 2 years.....
ndrifter
Posted 06 January 2011 - 04:23 PM
maybe just service it during my next checkup
add coolant? i really cant recall when i do that,
duno inside is dry up already or not, haha..
Posted 06 January 2011 - 04:35 PM
Radiator is very important leh! I check at least once a month the level of the coolant.....
Don't wait until the radiator coolant goes rusty then the internal may be damaged......
ndrifter
Posted 06 January 2011 - 05:12 PM
will do!
Posted 08 January 2011 - 03:22 PM
will do!
What coolant do you use?
kohf1drive
Posted 09 January 2011 - 04:34 PM
Use oil base type for our climate
ndrifter
Posted 09 January 2011 - 05:33 PM
my signature got, but wat is your recommendation ?
