3rd Group Buy - Engine Oil & Atf Oil
r3xt0n
Posted 08 March 2011 - 02:29 PM
r3xt0n
  • 5,148 posts
Order Deadline - 01 April 2011
Payment Deadline - 01 April 2011 (All payment to Bro ByeBye2U before the deadline)
Order Collection - From 09 April 2011 from designated bros.
Package 1 - RM288.00
i. Engine Oil Titan HPE Ultra 15W40 - 18 litre pack (sufficient for 2 change interval)
ii. Bosh Oil Filter - 2X (sufficient for 2 change interval)
Recommended Change Interval - 5,000km ~ 10,000km depending on driving condition.
Super High Performance Diesel Engine Oil for the most demanding requirement.
TITAN HPE ULTRA 15W40 is a long-life all season SHPD universal engine oil for high performance engines requiring the latest API performance in combination with top-tier ACEA specifications.
Specifications:
â�€š API CI-4/CH-4/CG-4/SL
â�€š ACEA E5/E3/B4/A2
â�€š GLOBAL DHD-1
â�€š MB 228.3/229.1
â�€š MAN 3275
â�€š VOLVO VDS-3
â�€š CUMMINS 20078
â�€š Mack EO-M+
â�€š MTU Oil Category 2
â�€š RVI RLD
â�€š CAT ECF-1
Benefits:
�€š· Long-life SHPD oil has ample reserves to cope with extended oil change intervals.
�€š· Enhanced anti-wear characteristics.
�€š· Provides effective protection against piston ring wear, rust and bearing corrosion.
�€š· Optimised cold start and fast warm-up.
�€š· Good oxidation resistance and reduced varnish, lacquer, sludge and carbon deposit formation even in severe service operation.
�€š· High lubrication oil film strength protects heavily loaded valve train gears.
�€š· Protect against bore polishing, scuffing and minimizes cylinder liner wear.
�€š· Excellent dispersancy retains soot and harmful oxidized products in suspension, aids filterability.
�€š· Good reserve alkalinity retention effectively neutralizes harmful acidic combustion contaminants and prevents premature wear in pro-longed oil service interval.
�€š· Good viscosity-temperature behaviour due to stay in grade characteristics even in very severe conditions.
Application:
�€š· TITAN HPE ULTRA 15W40 is recommended for major US, European and Japanese diesel engines such as Caterpillar, Cummins, Detroit Diesel Allison, Volvo, MAN B&W, MTU, Duetz, W�’¤rtsil�’¤, MB, Komatsu, Hino and others.
�€š· Developed for highly stressed normally aspirated and turbocharged diesel engines with exhaust gas recirculation (ERG) system.
�€š· Ideal all-season oil for mixed fleets, construction and earth moving equipment, marine ferries and industrial equipment with diesel engines.
�€š· Can be used in gasoline engines requiring API SL engine oils.
Package 2 - RM550.00
ATF Oil FUCHS Titan 3353 (as specified in spec) - 1 litre bottle X 9 bottle = 9 litre for full flushing or 2 drain off.
Malee Germany ATF Filter with Gasket - 1pcs
Recommended change interval - 60,000 km.
Order List
1. r3xt0n - Package 1 - RM288 - Paid RM288
2. Razopower - Package 1 - RM288 - Paid RM288
3. Rex4585 - 2 Pails Only - RM480 - Paid RM480
4. BK4t9 - 2 Pails Only - RM480 - Paid RM480
5. Spacebar - 5 Litre ATF Oil = RM250 - Paid RM250
6. BK4t9 - 4 Litre ATF Oil = RM200 - Paid RM200
7. tkw138 - Package 1 = RM288 - Paid RM288
8. phoong2323 - Package 1 = RM288 - Paid RM288
9. mu4ever - Package 1 = RM288 - Paid RM288
10.
Total Order = RM2,850
Payment Paid = RM2,850
Please add your name and package to be ordered. Any extra will be contributed to the Hub Funding.
razopower
Posted 08 March 2011 - 07:32 PM
razopower
  • 481 posts
QUOTE (r3xt0n @ Mar 8 2011, 02:29 PM) <{POST_SNAPBACK}>
Order Deadline - 16 March 2011
Payment Deadline - 16th March 2011 (All payment to Bro ByeBye2U before the deadline)
Order Collection - From 21 March 2011 from designated bros.
Specifications:
â��€�š API CI-4/CH-4/CG-4/SL
â��€�š ACEA E5/E3/B4/A2
â��€�š GLOBAL DHD-1
â��€�š MB 228.3/229.1
â��€�š MAN 3275
â��€�š VOLVO VDS-3
â��€�š CUMMINS 20078
â��€�š Mack EO-M+
â��€�š MTU Oil Category 2
â��€�š RVI RLD
â��€�š CAT ECF-1
Benefits:
��€š· Long-life SHPD oil has ample reserves to cope with extended oil change intervals.
��€š· Enhanced anti-wear characteristics.
��€š· Provides effective protection against piston ring wear, rust and bearing corrosion.
��€š· Optimised cold start and fast warm-up.
��€š· Good oxidation resistance and reduced varnish, lacquer, sludge and carbon deposit formation even in severe service operation.
��€š· High lubrication oil film strength protects heavily loaded valve train gears.
��€š· Protect against bore polishing, scuffing and minimizes cylinder liner wear.
��€š· Excellent dispersancy retains soot and harmful oxidized products in suspension, aids filterability.
��€š· Good reserve alkalinity retention effectively neutralizes harmful acidic combustion contaminants and prevents premature wear in pro-longed oil service interval.
��€š· Good viscosity-temperature behaviour due to stay in grade characteristics even in very severe conditions.
Application:
��€š· TITAN HPE ULTRA 15W40 is recommended for major US, European and Japanese diesel engines such as Caterpillar, Cummins, Detroit Diesel Allison, Volvo, MAN B&W, MTU, Duetz, W��’¤rtsil��’¤, MB, Komatsu, Hino and others.
��€š· Developed for highly stressed normally aspirated and turbocharged diesel engines with exhaust gas recirculation (ERG) system.
��€š· Ideal all-season oil for mixed fleets, construction and earth moving equipment, marine ferries and industrial equipment with diesel engines.
��€š· Can be used in gasoline engines requiring API SL engine oils.
Order List
2.razopower - Package 1 - RM288
Total Order = RM288
Payment Paid =
r3xt0n
Posted 08 March 2011 - 07:44 PM
r3xt0n
  • 5,148 posts
Bro Razo sold his old stock at RM250 to Bro AzharDollah and now got to replenish at RM288, you really generous la.. hahahaha
byebye2u
Posted 08 March 2011 - 11:17 PM
byebye2u
  • 2,805 posts
QUOTE (r3xt0n @ Mar 8 2011, 07:44 PM) <{POST_SNAPBACK}>
any bro want to sold old stock somemore..hahahaha..sapa cepat dia dapat.
r3xt0n
Posted 09 March 2011 - 12:52 AM
r3xt0n
  • 5,148 posts
QUOTE (byebye2u @ Mar 8 2011, 11:17 PM) <{POST_SNAPBACK}>
There might be another price increase soon, maybe from April. So, better hurry to stock up. The current price is the old price from Jan 2011.
rex4585
Posted 09 March 2011 - 06:11 AM
rex4585
  • 681 posts
QUOTE (r3xt0n @ Mar 9 2011, 12:52 AM) <{POST_SNAPBACK}>
Bro I want the engine oil without the oil filters. Ok? How much? 2 pails please
bk4t9
Posted 09 March 2011 - 08:28 AM
bk4t9
  • 349 posts
QUOTE (rex4585 @ Mar 9 2011, 06:11 AM) <{POST_SNAPBACK}>
Bro,
same 4 me engine oil without the oil filters. Ok? How much? 2 pails please
<P> </P>
razopower
Posted 09 March 2011 - 05:17 PM
razopower
  • 481 posts
Hahahahha......wat are brothers for ....kekekek.... as long as everybody is happy and smiling....lol
r3xt0n
Posted 09 March 2011 - 06:02 PM
r3xt0n
  • 5,148 posts
QUOTE (bk4t9 @ Mar 9 2011, 08:28 AM) <{POST_SNAPBACK}>
Bro,
Just engine oil alone is RM240. So 2 pails is $480.
phoong2323
Posted 13 March 2011 - 06:21 PM
phoong2323
  • 80 posts
QUOTE (r3xt0n @ Mar 9 2011, 06:02 PM) <{POST_SNAPBACK}>
Hi,
I am having a 270xdi Rexton for a couple of years now. Have been using Caltex Delo400 for oil change, but intermittently used SC oil whenever Caltex Delo400 out of stock. Thinking of trying Titan. Can I buy 1 pail 18L even if I am not a member of your club yet?
My ride: 2004 Rexton xdi270, part-time, auto-foam, koni yellow, k&n.
