#51
wirahijau
Posted 12 April 2011 - 06:09 PM
Bros who have installed the Rubber Damper today, please share your experience and feedback. We will be placing order for more soon.
Finish installing rubber damper yesterday n monitoring past 2 day
Noted the superb improving in corner n body roll. Slow bump ok but speed bump feel harder
Currently using 31 psi on tyre,will try to reduce 29 n see. But scared to see tyre buncit
#52
r3xt0n
Posted 12 April 2011 - 08:37 PM
Always remember the pressure is not 100% accurate and repeatable at all station, best to test out at one of the station that you usually go and determine the right PSI suiting your ride. Mine felt right at 215kpa (31.2 PSI) but when check at the tyre workshop is only 28PSI.
#53
tkw138
Posted 12 April 2011 - 08:44 PM
Can you measure the following dimension if there is one suits your Toyota SEG
1. Diameter of Spring Coil
2. Gap between each coil of spring
Adding Damper will helps to absorb the impact from bump better.
Hi Bro,
The spring shape like a long cone.
I measured the center diameter is about 18 inches for front & 16 inches for rear.
The gap between is 2 inches w/o load.
Please help me ask the vendor if he is carrying rubber damper in this size.
Thanks in advance!
KarWoh
#54
tkw138
Posted 12 April 2011 - 09:07 PM
Agree bro, feel much better after install the rubber damper.
They work perfect, increasing spring's stiffness thus reduce body roll when making turns especially on the rear.
Thumbs up!
#55
r3xt0n
Posted 12 April 2011 - 09:24 PM
Hi Bro,
Thanks in advance!
KarWoh
How about the thickness of the spring itself?
#56
tkw138
Posted 12 April 2011 - 09:34 PM
The thickness looks slightly thinner than Rex's spring.
#57
r3xt0n
Posted 12 April 2011 - 09:49 PM
Maybe your Koni is a bit harsh, so you will feel harder on speed bump. Koni can be adjusted for its hardness right? Sometimes difficult to achieve best combination because hard suspension improve handling but not as comfort.
#58
wirahijau
Posted 18 April 2011 - 07:30 PM
update
after 1week installed got improvement in comfort. now it firm not harsh anymore although not changing tyre pressure yet(no time)
for body roll and cornering still same=
good
#59
mu4ever
Posted 19 April 2011 - 01:27 PM
mu4ever
You guys are really lucky. I bought mine at RM235 + RM30 installation whereas now it is only RM80+RM20 installation. Less than half of the price doing the same job. hahahaha
Bro,
I am interested in the RD - Where to buy it or install it?
#60
r3xt0n
Posted 19 April 2011 - 02:03 PM
Bro,
Place your order here, make payment to our Hub Account and collect during Group Lunch on 07 May. On that day itself, those who needed installation can go to our panel workshop together.
