New Blm Problem
#141
Posted 05 May 2012 - 12:23 PM
My BLM yr 08 with 75k km on the odo.
After warranty, no more breakdown.
Engine spec(barely mod)
-open pod Simota
-grounding cable
-NGK Iridium plug
-tiny blade in intake(i think its called surbo) and yes, it works
Chassis
-UR rear ARB
-UR 2 point front tower bar
-UR 4 point lower arm bar
Suspension
-Previously on Sapura Proride sport spring which makes it great with UR bar, now back on stock.
Brake
-rear OE
-front aftermarket pad, forgot the brand
Top speed on meter was 180kmh, no proof of this.
Top speed recorded on GPS is 172kmh achieved last week at Lekas.
#142
Posted 20 October 2012 - 10:45 PM
Anyone change the engine head gasket before?
I went to wakil service center this morning. There are some engine oil leakage mark from the engine head. The mechanic said the gasket get harden already and need to be replaced, which cost around RM120++ (incl. labour charge). My car mileage now is 50k only.
In my opinion, only old car will have this situation... kns...
#143
Posted 21 October 2012 - 03:23 PM
I doubt u are referring to the head gasket.
I believe its the valve cove gasket or rocker cover as some people call it.
Its just a simple rubber gasket.try tighten it abit more and see if it stop leaking.
It not then replace it.outside it cost less than rm100.
Head gasket dont simply leak without going through overheating or very high mileage.
If it is the head gasket then make a claim.
#144
Posted 21 October 2012 - 05:08 PM
bought it once non ori get it rm30 and labour 30 (not cheap), =rm60 ,
if diy ,,its just 30rm.
#145
Posted 22 October 2012 - 11:47 AM
Ya... i think you are right... it should be valve cove gasket... will try to tighten it...
Thanks ya..
#146
Posted 16 December 2012 - 11:58 PM
Thanks ya..
Just noticed something. The engine oil is actually leaked from the Engine Oil Cap... omg... just wonder somebody has changed the original engine oil cap... Anyone encounter such a problem?
#147
Posted 17 December 2012 - 12:04 AM
#148
Posted 08 March 2013 - 09:57 PM
#149
Posted 13 April 2013 - 11:36 PM
my car's clutch problem rectified. I went to another SC in puchong (jln serindit).. the boss Mr.Tang identified the problem and changed a new clutch master cylinder 2 weeks ago.. now so far so good..
