Proton Exora
#701
Posted 29 September 2012 - 06:30 PM
Yes have to remove the whole bumper.
If need to replace thing at the bumper has to remove the whole bumper.
Good design.
The only casualty is my plate no.
Broke off during dismantling to get to one nut of the bumper behind it
If anyone need help to remove his or her EB front bumper let me know.
Did not take any photo as working alone.
#702
Posted 03 October 2012 - 09:01 PM
which bulb?? LED or signal bulb?
mine own DIY only... not much difference, just main main only.
#703
Posted 03 October 2012 - 09:03 PM
Good design.
finally got sifu bukak bumper here...
even install bm horn, also have to take out bumper.
#704
Posted 19 October 2012 - 08:48 AM
Any recommended aftermarket reusable air filter?
Any recommended longer life spark plug? I was quoted RM8 for a set of OEM campro spark plug at spare part shop. Is this real? (unless it's RM8 a piece)
#705
Posted 19 October 2012 - 08:00 PM
#706
Posted 26 October 2012 - 07:59 PM
urs is CPS or CFE?
stock CFE spark plug alr iridium... few hundred buck oooo...
should be easy to replace signal bulb right...
#707
Posted 29 October 2012 - 01:59 PM
1. Head light still got water vapour..same light was changed last time..confuse..confuse..
2. Aircond belt still making noise...
3. Rear brake light dim..now the left one..last time right one..
Has to waste another annual leave for this unneccessarily.
#708
Posted 29 October 2012 - 02:38 PM
CPS lor.
For the rear lights, taking out the two screw won't loosen it. I suspect you need to loosen up the two nuts below it too. It's painted, so the guys at SC would know if you're taking it out
#710
Posted 05 November 2012 - 04:24 PM
For the aircond related noise, they changed the tensioner bearing. Not sure why they did not check this before during my first complaint. Last time only spray belt...haa..only spray and said ok.
Head light fogging, they said already tested and found ok. Not sure how they test it as I did not see and water being used.
Should have just replace the thing. The service officer also ask, how much fog and lasted for how long. What the heck!!
Fog is still fog, headlight not suppose to have fog inside. Sure that thing will start fogging again sooner or later. Maybe I just put silicon glue all around. Else need to get another annual leave.
Waited for 4 hours to get both above done and 15k service.
Very good service..not..
Only decided to go there because they already have my previous complaint.
Once again, I am not complaining. I get what I paid for.....aiseyman
