alan,
sorry to intrude. is if possible for you to share details to this fan conversion. i have always been a DIY person. but have never had any idea to deal with this conversion. my main concerns are bracket, thermo switch and aircond fan trigger. appreciate if u could elaborate. pleaseeee.....
Unser - Q & A
aryfs
, Jun 28 2001 11:54 AM, 5834 replies to this topic
#5832
Posted 17 January 2010 - 03:08 PM
Firstly, I chose the fan from hyundai getz because the frame is about the same size as the radiator. Just make some L brackets and mount it to the original screw position for the fan shroud.
The thermo switch is taken from a p/saga. Send the radiator to a radiator shop and they just need to drill a hole and weld a nut to fix the sensor.
I use 2 separate relays for the wiring. One gets the signal from the thermo switch, the other from the a/c compressor. The fan will turn on when either one gives the signal.
THE "engine-near"
#5833
Posted 19 January 2010 - 02:03 PM
alan,
thanks for the info.
now will try search for a copper or aluminium nut.
iron will seize.
iron will seize.
#5835
Posted 05 November 2017 - 11:05 PM
Hi all. Anyone still using this mighty MPV?
Going to change suspension soon. Any recommendation of which brand is good?
