optra 1.6 vibrate at 80kmh 2200 rpm
Posted 08 November 2006 - 03:44 PM
i have a funny problem here, car vibrates at 80kmh at 2200 rpm..anyone
have similar issues?
optra 1.6 auto..
the stuff that i have checked:-
1. spark plug (replace with ori) - not the problem
2. TB - this one was replaced and is a new one. should not be the
problem..
pls advise
Posted 09 November 2006 - 12:57 AM
problem and cause your car vibrate.
Posted 09 November 2006 - 09:22 AM
the engine to vibrate as well.
Posted 09 November 2006 - 02:41 PM
vibration at 80kmh 2200 rpm, and you suspect may be the drive shaft
problem, ask them to check.
Cheers!
Posted 30 December 2010 - 11:44 AM
optra 1.6 auto..
problem..
pls advise
hey i have the same issue now... nothing seems to work. check and changed plugs, cable, TB, mountings and ECU. Next should be the Driveshaft....
Posted 30 December 2010 - 04:10 PM
Sounds more like a wheel balancing issue to me.. are you rolling on standard rims or sports rims?
Following are the possible causes:
1) Wobbly rims
2) Tire uneven wear
3) Tire swollen
Try to check the tire condition and do wheel balancing....
Broken driveshaft normally vibrates your car under acceleration, not when cruising. Try to free your gear at 80km/hr and see if it still vibrates. If it does, the wheels is the problem...
Posted 12 February 2011 - 07:20 PM
1) Wobbly rims
2) Tire uneven wear
3) Tire swollen
Agreed...if vibrate when accelerating most prob yr drive shaft.....My car got that vibration prob when accelerating from 80 to 110kph, change the drive shaft and prob solved....no more vibration
Posted 05 August 2011 - 05:36 PM
Nope! all ok but still vibrates. its not like a bengkok rim or anything that feels like that. feels like the engine is not held on properly but i have changed all mountings too... drive shaft is ok according to the technician.
Posted 01 November 2013 - 02:02 AM
optra 1.6 auto..
problem..
pls advise
I have the exact same problem, it only vibrates when it shifts from 3de to 4th which normally happens at 80 kmh...I have send my car back to the dealer to check, they call it " shift shock" they made adjustments, made the car better for a wile but 2 months latter had the same problem. I think it is a gearbox problem, computer software, the computer it self or some thing electronic. I have found that you can push throw the vibration by accelerating slightly. I have all so find that some times the gear gets stuck in 3de or 4th when you stop at a light or roundabout and the car stalls when you pull away this is dangers and only happened to me 3 times... The biggest problem is that this only happens some times or most of the time, but not every single time. it is not the tigers because the vibration stops as soon as the 4th gear engage.
The other thing I have found is that the intensity of the vibration gets worse offer time, I have had the car at the dealer 4 times now with the same problem, sending it back for the 5th this week. Maybe 5 is charm?
Posted 13 February 2014 - 11:39 AM
