Kiamtiap or all,
My abs issue not really the warning light. My front left (passenger side)
can't seem to release the caliper. It happen regularly if weather is hot or
doing hard braking. The Proton suspected the ABS issues. Have you guys
encountered this issue before ? Is the ABS modulator going crazy ? Please help.
ABS System Repair Service
Kiamtiap
, Sep 15 2007 10:40 PM, 63 replies to this topic
#62
Posted 03 May 2008 - 09:57 PM
Hello dlrowotua.
ABS issues would usually trigger the warning lamp (and brake warning in
some cases). However, you also need to verify if the lamp is indeed
working - it lights up before you start the engine.
If it is indeed grabbing brakes, the brake piston could be stuck. This
can be either serviced or replaced. By the way, when did you last do a
fluid bleeding?
If you wish to have it checked, do let me know. I can take a look. My
number is 017-2721609. Locking brakes on one side is a risk. Your car may
swerve or spin under severe braking.
fluid bleeding?
#63
Posted 10 December 2015 - 01:37 PM
hi Kiamtiap,
is by any chance u r still here and still do ABS servicing?
