Proton 4G93 Timing Belt Price
Abin
, Jul 01 2003 05:25 PM, 16 replies to this topic
Posted 01 July 2003 - 05:25 PM
Hello everyone,
I'm driving a Wira 1.8 DOHC. Bought it 2nd hand with 93K kms and now its
approching 160k kms and I think its about time for a timing belt change.
Since this is my 1st experience with 4G93, maybe some of you out there cud
share with me your experience with changing their 4G93 t/belt. How much
wud a PROTON part and MMC differ and where to get the MMC original at a
good price. Could it be cheaper in Jalan Ipoh KL.
Also what are the other things I shud also change?. Seals..bearings etc.
Appreciate your response. thanks buddies..
Posted 02 July 2003 - 11:57 AM
Mine cost abt RM500 altogether.. MMC Parts.. Bearings, Oil Seals, 2
Belts, Labor.. forgot whether they put in tensioner or not..
Posted 02 July 2003 - 05:44 PM
Gunter..
Really!..that expensive aaa?. I thought cud get around RM300++. Didn't
expect I have to pay RM500 for t/belt replacement. Got to find a good shop
la if that is the case...otherwise kena tipu because somebody said can get
RM300 only. It cud be the ciplak one.
Posted 02 July 2003 - 05:55 PM
Hi Abin..
Did the owner change the timing belt before? If still not, I'm consider
you as lucky because the lifetime of timing belt is either 60 000 km or
100 000 km. Usually, it is recommended to change it before the due date.
If let say, u r using a 100 000 km lifetime timing belt, u should change
it by 80 000 km. Sometime the belt brake up before the expected
lifetime. My friend 'putus' the timing belt when the he had 79 000 km.
As a result, he has to spent about RM 1500 to repair his car.
I already change my timing belt when i do 80 000 km. It cost me about RM
380 (parts and labour). I'm very sure that i got an original part
because it's from MMC. It is a Timing Belt Kit (all in one box; belt,
bearing, tensioner etc.) So, make sure you get the right price and the
right parts before change your timing belt.
Posted 02 July 2003 - 06:09 PM
minyakitam,
tensioner as is hyradulic timing tensioner.?
sure or not? that piece itself would cost like RM 350 as it seldoms kaput.
can you still get the TB whole box kit at the same price today?
cheers.
migs
cheers.
migs
Posted 03 July 2003 - 09:26 AM
minyakitam,
the previous owner had already changed the t/belt at 96k kms. I'm reaching
160k kms soon. So got to budget la for the next change say at 180k kms.
Did u source the parts yourself or got it from your mechanic?
MIGS,
is there a hydraulic timing tensioner?..what is that?. I only know of
hydraulic lifters in 4G93. Just replaced mine with a used one from a good
friend in the forum. The irritating noise in the morning now is gone.
How to diferentiate between ORI MMC and NON ORI MMC. Is there any signs
or whatsoever that I shud look for?
MIGS,
Posted 03 July 2003 - 12:16 PM
Abin,
If i were you i would change the timing belt immediately. Reason being 2nd
TB change. After sometime the TB pulley might get sharpened and thus
changing the TB early helps to avoid unnecessary risk.
The HTT is there to adjust should your TB slacken up. Normally the HTT has
a pin of which eventually is released so that the TB is hydraulically
tightened.
Bout the ori and non ori MMC TB, dunno...maybe others can shed some lite.
Mine is ori coz the ori ones feels different... By looking at it you
should be able to tell.
cheers
migs
tightened.
cheers
migs
Posted 04 July 2003 - 01:12 AM
hello abin,
I changed my belting for wiraLE RM220 plus 2 bijiks of bearing RM120 last month.what
brand i dunno lah.the mekanik kata original mitsubishi what the heck.for complete list lebih
kurang punya what i did last month pi cari kat thread "wira service info FYI only".aku
ingat nak kena klik nombor tiga kat bawah tu aku rasa.I dunno how to paste thread cam
korang selalu buat tu la...tak pandai...so,selamat menukar talisawat Encik Abin.
Posted 04 July 2003 - 02:03 PM
Jepp,
Jadi basically kena budget around RM300++ la. Price yg ko kena tu kira ok
la tu. Masa aku tukar 1.6 aku punya dulu pun more or less at that price
jugak but confirm original MMC sebab the belt tak ada joint...it comes as
a whole belt. Tak ada trace jahit.
Right now pakai 4G93..no experince at all so I have to ask la you guys out
there where to get MMC t/belts at very good price. Better safe than sorry
kan..thanks brader
kan..thanks brader
