berlingo
#161
Posted 10 November 2008 - 10:04 AM
Just recently check with asliauto USJ, but temporary out of stock.
anyway, u can contact ah hon or ah chai at 0356214191 for new price. i
still waiting for the price come back after call up tis morning.
My berlingo considered still OK, only timing belt yet to change, already
clocked 55000km, maybe done by end of tis year.
david//
#162
Posted 10 November 2008 - 10:27 AM
55000km... your berlingo is quite new. Everything must be in good
condition. still very enjoyable.
I changed my timing belt at 72,000KM. I didn't change the water pump that
time, because no leakage. But, a bit regret when it reached 110,000KM.
Although no leakage, but the water pump created some noise during cold
startup. After that, went to workshop and changed it then pay extra labor
charge. May be you can consider to change your water pump with timing belt
together.
#163
Posted 10 November 2008 - 11:38 AM
Asliauto's ah chai just called back, he mentioned due to the shortage
supplies, the price has been increased to RM800, woah..... sky height
price,cannotlah...... i think better KIV first. If really urgent, go for
RM600 one.
Spmoi,
Need to allocate how much $$ for replace all belts + bearing + water pump
+ rubber seal + Labor???
david//
#164
Posted 10 November 2008 - 12:26 PM
your car sound so new.. 55000KM niah....my one already 200K liow
#165
Posted 10 November 2008 - 02:27 PM
My berly daily uses, but the route only PJ--puchong, puchong--pj. Now
realise tat clutch get harder and harder, beside tis everything OK!
#166
Posted 10 November 2008 - 03:43 PM
my timing belt was changed 3yrs ago. Timing belt+Bearing+Labour is
~RM500.00. Water pump+Labor is around RM210. If you change all Timing
Belt+Alternator Belt+Water Pump together... then you will save >RM100 of
labor cost.
Normally, Alternator Belt and Water Pump can drag to higher mileage...
Virtually, it seem like save our pocket money. But, we go to change it
separately and we pay for additional labor cost. It seem like same. So,
change all together might be easier for us to monitor. This is just my 2cent.
#167
Posted 11 November 2008 - 10:10 AM
izzit 1 belt to handle alternator/fan/power ster/aircon? mine one is
berly II. Now is the time source for all those parts, i believe s/p price
will increase next year.
david//
#168
Posted 11 November 2008 - 11:17 AM
open you engine bay.
Look at the right side of the engine. It should see a black plastic cover
covering the right side of the engine from top to bottom. Inside the black
color plastic cover is the timing belt.
At outside, you can see the alternator just sit behind your engine near to
the steering and the aircon compresor just sit infront of of engine near to
the radiator. There will be a belt for alternator and a belt for air-con.
if you want more detail info.. you can ask Tony from euromotive.. because
he is berly owner and very familiar with berly...
#169
Posted 11 November 2008 - 12:30 PM
steering and aircond compressor. Change its once at EXD ukay for RM80++ if
not mistaken.
#170
Posted 12 November 2008 - 08:30 AM
so onece loose bell, then can not jalan already
one for aircond and one for alternator +.......so if aircond bell loose,
only no aircond but still can jalan, price wise, not much difference.
