Injector Light is ON!!
jararaca
, May 18 2005 11:49 AM, 27 replies to this topic
Posted 18 May 2005 - 11:49 AM
Does it indicate the failure of the O2 sensor if the injector is ON and
OFF when you drive.
OFF when you drive.
Posted 18 May 2005 - 09:36 PM
could be due to any of the engine sensor failure, btw what's your ride?
Posted 18 May 2005 - 10:02 PM
Have you checked using the Alfa/Fiat Examiner? There should be an error
record.
record.
Posted 24 May 2005 - 08:34 AM
hi there,
not too sure how you got it fixed but lambda sensor failure surely does not
result in injector light warning. that's for sure. it must have been
something else.
anyway, since you've got it fixed, good for you.
something else.
Posted 24 May 2005 - 09:29 AM
it actually blew the 7.5 fuse in the engine bay. there was an error
registered on the scanner on the lambda sensor.
You can actually read the realtime data for the sensor after replacing
with a new fuse. The reading was not responsive and the fuse kaput again
in minutes. same error recorded again.
After the replacement of a new bosch sensor, it is now working good for 2
weeks. no injector light!!! no new errors generated. So must be fixed lah.
Posted 26 May 2005 - 07:57 AM
This also happened to me last week. The injector light stays on. Diagnose
machine indicates air flow meter error. Checked and got the relay, (near
the brake oil tank) changed. Problem solved. But today, I notice the
injector light start blinking whenever I hit above 3,000 rpm but there is
no other noticeable impact to the driving. Any idea, anybody?
Posted 27 May 2005 - 10:06 PM
...argh...must be the lump...sensor again. Go for another scan
again...of course, bring along RM500.00. Gee...eating bread for this
month liao!!!
month liao!!!
