Intercooler Broken
wing
, Oct 16 2012 12:36 PM, 22 replies to this topic
Posted 16 October 2012 - 12:36 PM
Hi all,
Anyone can recommend me a workshop to redo my intercooler?
The intercooler is broken at the side. Need a replacement unit but also need the workshop to modify a bracket to fit in the existing fan to the new cooler.
Prefer a place near Cheras area where possible.
Thx
Thx
My Kembara...almost anywhere also can.
Posted 16 October 2012 - 06:31 PM
QUOTE (vr2turbo @ Oct 16 2012, 02:51 PM) <{POST_SNAPBACK}>
Intercooler with fan?
since he mentioed broken at the site..i asumme it's radiator as commonly leak at the side. and further more only radiator need to pair with fan ..right ?
Posted 17 October 2012 - 08:37 AM
Hi all,
The rounded black is where it's broken and the rounded red is the suction fan where I'd want to have it on the new intercooler.
Any workshop recommendation and maybe a suggestion of a new intercooler?
Posted 17 October 2012 - 09:45 AM
QUOTE (wing @ Oct 17 2012, 08:37 AM) <{POST_SNAPBACK}>
Hi all,
so my quessing are wrong.. it's a intercooler that i never see in my life.
Ok, back to PS question..
for the broken alum clipper on the side, actually you can go to any Radiator service/exhaust shop that around u and ask for full alum welding on that particular parts. no need to replace with new IC.
and for the suction fan, i just can't help as dont know what is the specification of the fan..
Posted 17 October 2012 - 09:49 AM
Hi all,
agree with v4....go to any radiator shop to fully weld the seam.....
it is rare to se such turbo kembara
(NFS Underground)
Posted 17 October 2012 - 04:51 PM
can they even weld it back? The broken part is where the fins are connected to the seam...throughout the seam!
The cooler has a label - Nissan. I think SR20.
Posted 18 October 2012 - 07:48 AM
As far as I know, intercooler seldom break from there. Maybe a lot of vibration. Probably you will need a replacement instead.
To me, intercooler needs most cooling at high speed (turbo boost). Having a fan seems to block the air passage at high speed.
Posted 18 October 2012 - 09:09 AM
Very true vr2Turbo.
But mine does not have an opening on the bonnet for air to go through it. Thus, the fan to assist in pulling the air through it. Need this setup as the Kembara does offroading and occasionally go cruising some river.
something like this....
That's why I need the bonnet closed and the cooler high up. Less likely to be damaged.
So anyone can recommend a workshop? Need it repaired ASAP.
