Engine Oil Filter
br1
Posted 07 June 2012 - 09:49 PM
br1
  • 2,825 posts
QUOTE (vr2turbo @ Jun 5 2012, 04:40 PM) <{POST_SNAPBACK}>
Filter don't cost much leh! should change at every oil change.
Did you remove the filter and pour the dirty oil out, if not it will mix with your new oil.... smile_shock.gif
some are quite costly too, depending on cars!!! but 2 oil changed / filter is NO No to me!!!!
bpguan
Posted 07 June 2012 - 10:33 PM
bpguan
  • 123 posts
QUOTE (vr2turbo @ Jun 7 2012, 08:38 AM) <{POST_SNAPBACK}>
Probably torque with tools? oil filter for me is always hand tighten...... smile_thumbup.gif
yup agree on unker...for my diy case...hand tighten the oil filter...our hand got the torque for the oil filter specify torque...while loosen it...use oil filter wrench(3 claws type)
btw got a Q to ask..so do the original filter last 10k OCI?as i knw there's a valve inside the oil filter where when the filter element got blockage...the valve will open & there's no filtration anymore...
Posted 11 June 2012 - 11:31 AM
  • 71,865 posts
QUOTE (bpguan @ Jun 7 2012, 10:33 PM) <{POST_SNAPBACK}>
10k km for oil filter should not be a problem unless your engine is dirty. If dirty, then even your oil OCI should be earlier.
I used to do 10k km or 6 months whichever comes first, but have brought it down to 3 months or 5k km for my turbo.... smile_tongue.gif
MM
Posted 11 June 2012 - 09:38 PM
MM
  • 313 posts
QUOTE (gjrforce @ Jun 7 2012, 01:39 AM) <{POST_SNAPBACK}>
i am using K&N synthetic oil filter for 15k km oil change interval application or Nippon japan oil filter for 10k km.
Yo gjrforce!
May I know where did you buy those K&N oil filters, please?
Thanks
ring
Posted 10 July 2012 - 12:29 PM
ring
  • 1,628 posts
QUOTE (vr2turbo @ Jun 11 2012, 11:31 AM) <{POST_SNAPBACK}>
About OCI, it is very much depending your driving style, lubricant quality used and very own personal liking.
My business is in lubricant. Though I should advocate frequent OCI but I would not because each individual drive style is different.
My view is if you are always in city with frequent stop & go condition then only you consider OCI. This is also consistent with most car manufacturers that cover under "Severe Driving Condition" drive condition.
Pointer like oil generation grade is important. SM grade will have better protection than SG or SL as it inhibits slug, vanish & carbon. Next just take a look at its bottling and no to bother those local brands coz not all follow API standard.
Ring
Posted 10 July 2012 - 02:56 PM
  • 71,865 posts
QUOTE (ring @ Jul 10 2012, 12:29 PM) <{POST_SNAPBACK}>
Yes, under severe conditions a shorter OCI should be considered, but older engine on newer SM oil may not necessary be better as they have less zinc additives....
ring
Posted 24 July 2012 - 04:56 PM
ring
  • 1,628 posts
QUOTE (vr2turbo @ Jul 10 2012, 02:56 PM) <{POST_SNAPBACK}>
Actually for older engine one needs to observe API grade. Newer tends to have better cleaning agent, low carbon & not the older ones. Which also translate higher price.
i.e. 1 cents Gets 1 cts (better) goods (Read in Cantonese smile_wink.gif )
Ring
Tham58
Posted 25 July 2012 - 02:25 AM
Tham58
  • 67 posts
QUOTE (vr2turbo @ Jun 5 2012, 01:40 PM) <{POST_SNAPBACK}>
The filter fills with less than half a liter of oil, so the old oil
mixing with nearly 4 liters of new oil is of insignificance, I guess.
Taking out and reinstalling the filter may mess around with the O-ring,
with the risk of causing leaks later.
So I played safe and just left the filter as it is.
cygnus
Posted 25 July 2012 - 11:46 AM
cygnus
  • 1,771 posts
Beside old oil in the filter, there is plenty more sticking everywhere in the engine. U wanna clean it as well?
Under normal driving condition, there's almost nothing get trapped in the canister. I have cut open some.
Hence we should prolong the usage of oil filter. To me, changing at every oil change is a waste of $ and environment-unfriendly.
Posted 25 July 2012 - 06:13 PM
  • 71,865 posts
Park for a while before draining and also drain longer period...... smile_tongue.gif
