Questions and answers on CVT Saga, Exora, P3
#261
Posted 26 December 2014 - 04:36 PM
What both of you wrote was positive in regard to Proton and its capabilities. I wonder why Proton themselves came across as being so negative about their own products.
I will have to find out how Low works on Protons CVT. It must be a pressure, or other signal from the computer as it is not using a different a different gear ratio when low is engaged
Terry
#262
Posted 30 December 2014 - 10:13 PM
Terry
Thats Proton's problem of employing some idiots smarlty dressed as high ranking
exec and eg.
last time at Cameron i did try using L on the steep slope.
i found it to be too low and did not provide engine braking like a normal auto would.
i just leave it in D.
Its very low,if u jave driven a manual 4x4 in 1st gear u will understand.
i think its programmed for super duper steep slope.
#263
Posted 29 May 2015 - 09:27 AM
greetings kristof,
it has been long time since we meet up to flash the TCU.
Saga flx 2012 jun, VT2 gearbox, now running 36,000km, (not yet change belt, battery (for battery running at 1 year 4months), not yet service gearbox), change plug (but don't know they (SC) really change it or not).
Issues
recently feeling not smooth in change from 2nd gear to 3rd gear when reaching 40km/h or 50km/h when in not very steep slope and worst in steep slope. Like punching forward in short when shifting period occurs. What is the problem?
#264
Posted 29 May 2015 - 09:30 AM
very strangely, air con will on at 40km/h? it suppose to depends on the temperature sensor or it has been programmed to run air con at 40km/h?
#265
Posted 29 May 2015 - 04:56 PM
#266
Posted 13 August 2015 - 05:57 PM
Just to share..
11/8/15, My Exora Bold CFE (2012) started to jerk near Masjid Negara. CVT gearbox and engine light up. This is the 2nd time. It was raining super heavy an hour before. Called towing and went to Balakong SC. Mechanic checked w diagnostic laptop.
It seems that water from A/C condensation in the dashboard area was dripping into CVT Computer box. The box is located behind centre console panel of dashboard. CVT computer box new costs RM2800.
Mechanic said will try to repair but usually not succesfull and need to replace. Newly facelift model rectified this problem.
Do you think this is a design fault and should I claim from Proton??
#267
Posted 22 March 2016 - 02:31 AM
I own a Saga FLX since Feb 2014. Recently, the CVT warning indicator (red) on the dash started flashing. It appeared for a moment then went away. This repeated a few times and then it stopped flashing. It had been a few days since it lit up.
Should I bring the car in for a check up?
#268
Posted 08 January 2017 - 06:47 PM
I got problem here..
When i shift my gear to P the dashboard stated N and the warning light appear
My car can still running per normal even the warning light suddently appear and suddenly gone
When i shift the gear to N or L the warning light disappear
I go many workshop including proton sc and gearbox speacialist.. They give a different answer from their different perspective
#269
Posted 09 November 2017 - 11:28 PM
Hi Dear,
Recently i just bought the Proton Persona CVT.
Found that the cvt gearbox jerk, in low speed, especially in traffic jam.
Is there any solution for this currently ?
Please advise.
#270
Posted 23 November 2018 - 02:35 AM
Very early morning kristof I'm a new owner of p3 saga 2018. Asking some of jerking happens when my car start moving.
1.This happen not often.
2.Then there a time feeling of lost sync with the gearbox.
3.There a time the gearbox resetting itself after a while when my gearbox already feel smooth.
Regard QAA7118V
