Oct 2011 Group Order
r3xt0n
Posted 26 September 2011 - 11:33 PM
r3xt0n
  • 5,148 posts
Order & Payment Deadline - CLOSED
Order Collection - 22 Oct 2011
1. Engine Oil Package
i. Engine Oil Titan HPE Ultra 15W40 - 18 litre pack (sufficient for 2 change interval) - $240
ii. Bosh Oil Filter - 2X (sufficient for 2 change interval) - $20/piece X 2 = $40.
Recommended change interval - 5,000km ~ 7,500km depending on drive condition.
2. ATF Oil Package
i. ATF Oil FUCHS Titan 3353 (as specified in spec)
- 5 litre/container (sufficient for 1 drain-off) - $250
- 2 X 5 litre/bottle (If full flushing, require 9.5 litre) - $500
ii. Mayle Germany ATF Filter with Gasket - 1pcs - $100
Recommended change interval - 40,000~60,000 km depending on drive condition.
3. OEM Hyunkai Absorbers (Front & Rear) - RM100 each X 4 = RM400
4. Bendix 4WD Brake Pad (Front & Rear) - RM290
5. Rear Shock Stopper - RM75/each = RM150
6. Upper Arm Bush (2pcs left & 2pcs right) - $30/pc X 4pcs = $120
7. Lower Arm Bush (4pcs left & 4pcs right) - $30/pc X 8pcs = $240
8. Transmission Mounting - $130
9. 1 set Engine Mounting (2pcs) - $130 X 2 = $260
10. Vacuum Modulator - RM250 each X 2 = RM500
11. OEM Vemo Coupling Fan Clutch = RM250
12. Coolant Sensor - $75
13. Air Filter (OEM - Made in Korea) - RM60
14. Diesel Filter (OEM - Made in Korea) - RM180
15. Water Seperator (OEM - Made in Korea) - RM250
16. Bendix 4WD Brake Pad (Front & Rear) - RM290
17. Contitech Fan Belt (2257) from Germany - RM80
18. Aircon Cabin Filter (Korea OEM) - RM50
19. Crank POS Sensor Sensor - RM150
20. Cam Sensor - RM170
21. Tie Rod & Rod End - RM190 / set X 2 side = RM380
22. Tailgate Gas Struts Lifter (Window) - Local brand = RM90 / piece
23. Gas Struts Lifter (front bonnet) - Genuine Original = RM 130
24. Power Window Motor = RM190
25. Rear Brake Shoe - Original = RM 450 / set of left and right
26. Glow Plug - Original - RM90 per piece
27. Thermostat & Gasket - RM130 / set
28. Front Brake Disc (Left & Right) Original - RM650/set
29. Rear Brake Disc (Left & Right) Original - RM600/set
Order List
1. Tkw138 - RM320 - Paid
2. Urchirex - RM50 Paid
3. JailOs - RM500
1. Bosh Oil Filter - 1 piece - Paid
4. Neonlee = $525
- Tufoil X 3 = $165
-Upper Arm Bush (2pcs left & 2pcs right) - $30/pc X 4pcs = $120
-Lower Arm Bush (4pcs left & 4pcs right) - $30/pc X 8pcs = $240
5. Zak - $410 - PAID
2 pcs Gas Struts Lifter (front bonnet) - Genuine Original = RM 130 X 2 = $260
Rear Shock Stopper - RM75/each X 2 = RM150
6. tsleong67 - $650 - PAID
- ATF Oil FUCHS Titan 3353 (as specified in spec)
- Mayle Germany ATF Filter with Gasket - 1pcs - $100
- Aircon Cabin Filter (Korea OEM) - RM50
- Water Seperator (OEM - Made in Korea) - RM250
7. GreyDevil - RM410 - Paid
i. Voltage Stablizer - RM160
ii. Grounding Cable - RM120
iii. Transmission Mounting - RM130
8. wsxnasser - $350 - PAID
2. ATF Oil Package
9. BK4t9 - RM360 - PAID
14. Diesel Filter (OEM - Made in Korea) - 2 X RM180 = RM360
Total Order = RM3,844
Payment Paid = RM2,550
Bros who wish to make their order, please post your list here and payment instruction will be PM to you.
jail0s
Posted 27 September 2011 - 10:38 PM
jail0s
  • 25 posts
Vacuum modulator x 2 sets
Do u have rear brake disc left & right? SC price is rm500++ per piece
r3xt0n
Posted 27 September 2011 - 10:56 PM
r3xt0n
  • 5,148 posts
QUOTE (jail0s @ Sep 27 2011, 10:38 PM) <{POST_SNAPBACK}>
Added your order. Got to check the price for rear brake disc and get back to you. Also added shortage of oil filter owed to you.
jail0s
Posted 27 September 2011 - 11:00 PM
jail0s
  • 25 posts
QUOTE (r3xt0n @ Sep 27 2011, 10:56 PM) <{POST_SNAPBACK}>
Thanks bro
phoong2323
Posted 28 September 2011 - 11:39 PM
phoong2323
  • 80 posts
QUOTE (r3xt0n @ Sep 26 2011, 11:33 PM) <{POST_SNAPBACK}>
Order & Payment Deadline - 17 Oct 2011
2. ATF Oil Package
Order List
2. Urchirex - Paid
3. r3xt0n - RM320
4. JailOs - RM500
5.
6.
7.
8.
9.
10.
Total Order = RM1,140
Payment Paid = RM320
Hi bro,
Can I ask what's the following used for?
Do you have pricing for front brake discs left & right? Btw my hand-brake is not "makan" so do I buy Rear Brake Shoe - Original = RM 450 / set of left and right?
Regards,
phoong
r3xt0n
Posted 29 September 2011 - 11:19 AM
r3xt0n
  • 5,148 posts
QUOTE (phoong2323 @ Sep 28 2011, 11:39 PM) <{POST_SNAPBACK}>
Hi bro,
Regards,
phoong
Tie Rod & Rod End is located beside Steering Rack linking to front tire. It required replacement if it is stuck, not rotating anymore.
Tailgate Gas Struts Lifter is the absorber looks-alike that lift and hold the rear window.
Original Front Brake Disc is about RM700/a pair of left and right (got to confirm with the Supplier, bought this about 1 year ago). Hand brake not gripping got to check if the setting can be adjust. It may or may not be related to brake pad.
r3xt0n
Posted 29 September 2011 - 09:21 PM
r3xt0n
  • 5,148 posts
Wah, our price is cheaper by almost 50% then.
Hi bro,
Regards,
phoong
Added both items to the Group Order List. It is good to replace the wheel bearing along with the oil seal when you replacing the brake disc. If you guys interested, will check out the price to include wheel bearing and oil seal as a package.
If you plan to change the wheel bearing and oil seal, better check out the thread on Changing Brake Disc for the photos and steps as it required to remove and resemble the ABS plate carefully.
neonlee
Posted 30 September 2011 - 07:05 PM
neonlee
  • 574 posts
Bro,
My order for Oct
1. Tufoil x 3
jail0s
Posted 01 October 2011 - 10:03 AM
jail0s
  • 25 posts
Add my oct order
Rear brake disc left right set rm600
Thanks bro
r3xt0n
Posted 03 October 2011 - 10:17 PM
r3xt0n
  • 5,148 posts
QUOTE (jail0s @ Oct 1 2011, 10:03 AM) <{POST_SNAPBACK}>
Add my oct order
Thanks bro
Added both orders.
