Posted 05 October 2011 - 12:03 AM
zak
Order & Payment Deadline - 17 Oct 2011
Order Collection - 22 Oct 2011
1. Engine Oil Package
i. Engine Oil Titan HPE Ultra 15W40 - 18 litre pack (sufficient for 2 change interval) - $240
ii. Bosh Oil Filter - 2X (sufficient for 2 change interval) - $20/piece X 2 = $40.
Recommended change interval - 5,000km ~ 7,500km depending on drive condition.
2. ATF Oil Package
i. ATF Oil FUCHS Titan 3353 (as specified in spec)
- 5 litre/container (sufficient for 1 drain-off) - $250
- 2 X 5 litre/bottle (If full flushing, require 9.5 litre) - $500
ii. Mayle Germany ATF Filter with Gasket - 1pcs - $100
Recommended change interval - 40,000~60,000 km depending on drive condition.
3. OEM Hyunkai Absorbers (Front & Rear) - RM100 each X 4 = RM400
4. Bendix 4WD Brake Pad (Front & Rear) - RM290
5. Rear Shock Stopper - RM75/each = RM150
6. Upper Arm Bush (2pcs left & 2pcs right) - $30/pc X 4pcs = $120
7. Lower Arm Bush (4pcs left & 4pcs right) - $30/pc X 8pcs = $240
8. Transmission Mounting - $130
9. 1 set Engine Mounting (2pcs) - $130 X 2 = $260
10. Vacuum Modulator - RM250 each X 2 = RM500
11. OEM Vemo Coupling Fan Clutch = RM250
12. Coolant Sensor - $75
13. Air Filter (OEM - Made in Korea) - RM60
14. Diesel Filter (OEM - Made in Korea) - RM180
15. Water Seperator (OEM - Made in Korea) - RM250
16. Bendix 4WD Brake Pad (Front & Rear) - RM290
17. Contitech Fan Belt (2257) from Germany - RM80
18. Aircon Cabin Filter (Korea OEM) - RM50
19. Crank POS Sensor Sensor - RM150
20. Cam Sensor - RM170
21. Tie Rod & Rod End - RM190 / set X 2 side = RM380
22. Tailgate Gas Struts Lifter (Window) - Local brand = RM90 / piece
23. Gas Struts Lifter (front bonnet) - Genuine Original = RM 130
24. Power Window Motor = RM190
25. Rear Brake Shoe - Original = RM 450 / set of left and right
26. Glow Plug - Original - RM90 per piece
27. Thermostat & Gasket - RM130 / set
28. Front Brake Disc (Left & Right) Original - RM650/set
29. Rear Brake Disc (Left & Right) Original - RM600/set
Order List
1. Tkw138 - RM320 - Paid
2. Urchirex - Paid
3. r3xt0n - RM320
4. JailOs - RM1,100
1. Bosh Oil Filter - 1 piece - Paid
5. Neonlee = $165
- Tufoil X 3 = $165
6.zak
2 pcs Gas Struts Lifter (front bonnet) - Genuine Original = RM 130
7.
8.
9.
10.
Total Order = RM1,905
Payment Paid = RM320
Bros who wish to make their order, please post your list here and payment instruction will be PM to you.
neonlee
Posted 05 October 2011 - 08:35 AM
Bro,
My order for Oct
1. Tufoil x 3
Bro,
Sorry additional item as bellow , my front wheel shaking like hell , need to do something on it ,wheel bearing times up...
-Upper Arm Bush (2pcs left & 2pcs right) - $30/pc X 4pcs = $120
-Lower Arm Bush (4pcs left & 4pcs right) - $30/pc X 8pcs = $240
r3xt0n
Posted 05 October 2011 - 10:56 AM
Bro,
Updated your order. If you changing the wheel bearing, need to change the oil seal and get a high temp grease too.
tsleong67
Posted 05 October 2011 - 11:28 AM
Bro,
I need the following.
Thanks.
r3xt0n
Posted 05 October 2011 - 02:48 PM
Bro,
Thanks.
Added your order, will PM you the payment instruction later.
wsxnasser
Posted 15 October 2011 - 10:36 AM
wsxnasser
Bro,
My order as follows
2. ATF Oil Package
Thanks
Posted 15 October 2011 - 11:52 AM
zak
Hi R3xt0n,
Can u pls pm me on ur payment instruction?
Thanks
r3xt0n
Posted 15 October 2011 - 12:04 PM
Bro,
My order as follows
2. ATF Oil Package
Thanks
Added your order.
Hi R3xt0n,
Thanks
Will PM payment instruction to all bros to make payment for their order shortly.
tsleong67
Posted 17 October 2011 - 10:34 AM
Bro,
Is the water separator 2 connection or 3 connection at the top? If it is 2 connection, please add 1 pcs for me. Do PM me for payment instruction.
r3xt0n
Posted 17 October 2011 - 11:36 AM
Bro,
It is 2 connection Water Separator, not Diesel Filter.
