Weird Sound From Back
Posted 11 September 2016 - 06:18 PM
  • 71,859 posts
True also, just to share. I have cleared my front nyek nyek sound today! Haha. Previously when I go through bump will have nyek okkk, after reading all the post from this forum, I asked the mechanic to change the anti roll bar bush for me. After changing, the sound was transformed into nyek, the okkk sound gone. So was still scratching my head, the foremen said it could be the absorber need time to check. Of course, I also went to other different workshop to see what other machenic says. Most of them suspect that it was the absorber or absorber link, but then I still have doubt with their word. And today, I went to another workshop that I used to go for, he applied some grease on it, and the sound was gone. But I read some of the post here says that applying grease won't last for long. So I asked him whether there is any ways to solve the sound permanently, like changing absorber? Surprisingly, he said inserting a rubber will do. So I requested him to do for me. I saw him using a pvc host to wrap my absorber spring, and guess what, the sound was GONE! Luckily I did not change the absorber earlier!
Oh! means the spring seat on the absorder. By inserting the pvc hose might not last too if the spring grinds into it. Hopefully it does not break and pop out....
kohf1drive
Posted 11 September 2016 - 08:29 PM
kohf1drive
  • 3,077 posts
Door panel, if the sound is metal origin, please look at the door lock mechanism
It got metal long hook, apply masking tape at contact point
Khayxiong
Posted 13 September 2016 - 04:10 PM
Khayxiong
  • 15 posts
Vr2turno, Then any permanent solution that you would suggest?
Koh1drive, I felt like it is the door connection part. Not the panel Lea. If is the door lock mechanism, who should I look for? Accessories?
Posted 13 September 2016 - 10:44 PM
  • 71,859 posts
Not that I know off. The spring seat on the absorber were design without any cushion. You are getting the sound due to the springs rubbing the metal seat due to it being dry and rusty, that is why when you oil it no more sound. Since already have the PVC hose, just use and see it is last. Worry about it if the sound comes back....
kohf1drive
Posted 16 September 2016 - 04:06 PM
kohf1drive
  • 3,077 posts
I mean the door plastic panel (in cabin)
Unscrew few screw (near door latch n around the corner)
Remove the panel
You can see the door lock mechanism
There is a metal hook. Apply tape
Khayxiong
Posted 17 September 2016 - 11:57 PM
Khayxiong
  • 15 posts
Alright. Will check on it if the sounds come back again. Cause it happen randomly.
