Weird Sound From Back
Posted 03 September 2016 - 04:32 PM
Ya I'm still the waja
Exposed rusted c pillar from the last accident repair
But still going strong, proper maintenance still a reliable workhorse
It's age, now small hiccup popping up
Like air conditioning from cold to hot (mix cold n normal air). It turns out the fuse is spoil
Finding good mechanics is still a gem
Posted 03 September 2016 - 07:21 PM
Wira and Waja are both work horses. Many of my friends still on the wira, some even modding them.....
Posted 08 September 2016 - 12:27 PM
Posted 08 September 2016 - 01:57 PM
Checked, the handbrake cable is okay. Nothing loose. I give up.
Your mechanic also gave up?
Posted 08 September 2016 - 10:20 PM
Posted 08 September 2016 - 11:53 PM
The thing with sound is you might hear it here but it could be some where else and it takes time to test and locate. Also it will require at least 2 persons, one to drive and the other to locate. Most mechanic don't want to do it because it is time consuming and very hard to charge the customer. Too much and customer will complain, too little they are wasting their valuable time
Posted 11 September 2016 - 12:56 AM
Posted 11 September 2016 - 07:52 AM
1. Anti roll bar
2. Engine mounting
3. Absorber mounting
4. Steering bush
5. Tie rod (come with bush)
6. Lower arm (come with bush)
If all change together will give you NEW ride feel
But not necessarily require, depend on the condition, usually around 5 years change all together will same some cost for alignment n man-hour cost
Posted 11 September 2016 - 09:46 AM
I mean doesn't *
