Crate Motors?
roocarroll
Posted 15 March 2014 - 12:39 PM
roocarroll
  • 597 posts
This one is a bit of a theoretical question; can you buy crate motors in Malaysia and is it legal to put a different engine in the car?
Posted 16 March 2014 - 11:59 AM
  • 71,866 posts
QUOTE (roocarroll @ Mar 15 2014, 12:39 PM) <{POST_SNAPBACK}>
As far as I know you can use different engines but the mounting points must be the same. No modifications of the mounting points are allowed.
Therefore in this aspect usually car of same make it is possible to change the engine but not engine of another make where the mounting points are different
V406198
Posted 17 March 2014 - 12:20 PM
V406198
  • 2,151 posts
QUOTE (vr2turbo @ Mar 16 2014, 11:59 AM) <{POST_SNAPBACK}>
But now a day, many manufacturers had share their R&D and also production with many other makers especially on engine design, just example of the famous Prince engine been share among BMW Mini, Peugeot, Citroen... so can these cars switch engine from their counterparts ?
2004 S60R. AT. Tit Grey. Nordkap. 18" Pegs. TME SportCat Exhaust DP & Cat Back System. TME Lower Spring. Garrett GT3071R. RC 750cc Injectors. FMIC. K&N Filter. Pegasus 3" CAI. IPD HD TCV. IPD HD Ignition Coil, IPD 25mm Front Sway Bar. UR Custom 23mm Rear Sway Bar. UR Front & Rear Strut Bars. Stainless Steel Brake Hoses. Audi TT DV, Saab 900 ATF Cooler. TkiMotorSportRacing & IPD HD Link Rod. H&R 5mm Front Wheel Spacer. Endless Sport 0-400 Front Brake Pad. ScangaugeII Diagnostic Gauge. Stages 2 Snow Performance methanol Injection.
Posted 17 March 2014 - 02:46 PM
  • 71,866 posts
QUOTE (V406198 @ Mar 17 2014, 12:20 PM) <{POST_SNAPBACK}>
As long as the engine mountings are the same and not altered. Just like Mitsu engine going into proton cars are allowed
V406198
Posted 17 March 2014 - 07:26 PM
V406198
  • 2,151 posts
QUOTE (vr2turbo @ Mar 17 2014, 02:46 PM) <{POST_SNAPBACK}>
mengchai
Posted 26 March 2014 - 04:27 PM
mengchai
  • 32 posts
Is this for pickUp or car?
roocarroll
Posted 07 April 2014 - 08:50 PM
roocarroll
  • 597 posts
QUOTE (mengchai @ Mar 26 2014, 04:27 PM) <{POST_SNAPBACK}>
It was for an old car I was looking at. It had a 2.6l engine that produced around 100hp. Slow and thirsty.
