This one is a bit of a theoretical question; can you buy crate motors in Malaysia and is it legal to put a different engine in the car?
Crate Motors?
roocarroll
, Mar 15 2014 12:39 PM, 6 replies to this topic
Posted 16 March 2014 - 11:59 AM
QUOTE (roocarroll @ Mar 15 2014, 12:39 PM) <{POST_SNAPBACK}>
As far as I know you can use different engines but the mounting points must be the same. No modifications of the mounting points are allowed.
Therefore in this aspect usually car of same make it is possible to change the engine but not engine of another make where the mounting points are different
Posted 17 March 2014 - 12:20 PM
QUOTE (vr2turbo @ Mar 16 2014, 11:59 AM) <{POST_SNAPBACK}>
But now a day, many manufacturers had share their R&D and also production with many other makers especially on engine design, just example of the famous Prince engine been share among BMW Mini, Peugeot, Citroen... so can these cars switch engine from their counterparts ?
Posted 17 March 2014 - 02:46 PM
QUOTE (V406198 @ Mar 17 2014, 12:20 PM) <{POST_SNAPBACK}>
As long as the engine mountings are the same and not altered. Just like Mitsu engine going into proton cars are allowed
Posted 17 March 2014 - 07:26 PM
QUOTE (vr2turbo @ Mar 17 2014, 02:46 PM) <{POST_SNAPBACK}>
Posted 26 March 2014 - 04:27 PM
Is this for pickUp or car?
Posted 07 April 2014 - 08:50 PM
QUOTE (mengchai @ Mar 26 2014, 04:27 PM) <{POST_SNAPBACK}>
It was for an old car I was looking at. It had a 2.6l engine that produced around 100hp. Slow and thirsty.
