Rondo's Battery Lifespan
buckeyes
Posted 14 March 2011 - 02:19 AM
buckeyes
  • 49 posts
My Rondo is 10 months old with mileage clock around 19700km. This past week, have been experiencing weaker start every morning and sometimes after few hours of parking. If the deactivated alarm horn sound is soft, it gets harder to start the car.
Sent to SC and they said my battery is in good condition. Not sure are they trying to deny my warranty claim till exceed 20000km or really there is nothing wrong.
Is the difficult start an indication that the battery is dying or is there any other problems. Anyone experiencing the same problem? What is the battery lifespan for Rondo. Please advice. Thanks.
setisfai
Posted 14 March 2011 - 09:01 AM
setisfai
  • 75 posts
Buckeyes,
Waranty for battery is 10,000km or 1 year if i'm not wrong, check again with Naza or MAA.
As for mine, batery died after 1 year 2 months but I never had your symptom. Mine suddenly cannot start after refuelling at petrol station and came without warning.
Make sure you buy the correct battery size (high) otherwise the black compartment have to be modified abit.
Hope thats help.
Kevin
Posted 14 March 2011 - 02:02 PM
Kevin
  • 4,080 posts
My original battery is still running strong at 2 years, 5 months smile_approve.gif
hun
Posted 14 March 2011 - 09:37 PM
hun
  • 140 posts
mine went flat this morning.....
14 months since i got my car | mileage 20,450 km.... warranty is until 20k only.....
now change to traditional battery....which u need to add water.....its longer lasting....
buckeyes
Posted 15 March 2011 - 01:34 AM
buckeyes
  • 49 posts
Hi All,
This morning when I deactivated my alarm, it was still weak. So, I went to my neighbourhood tyre shop and asked them to check my battery. Using their analog battery tester, it indicated bad on the meter.
Immediately called SC and sent in for checking again. 3 hours later, they told me that my battery is weak. They have taken picture (??) and will send to HQ for warranty claim.
Not sure why didn't they find out during my servicing on the 10th. In fact, the battery test report indicated "Good battery" on that day. Today's report indicated "Replace Battery". Sometimes so worry that there are hidden issues that we are not aware of and SC is not telling until the car broke down and need replacement. Rather disappointed... Luckily the battery failed before 20000km......
Anyway, thanks to Setisfai, Kevin and Hun for your response...
psyeo2001
Posted 15 March 2011 - 08:05 AM
psyeo2001
  • 17 posts
QUOTE (buckeyes @ Mar 15 2011, 01:34 AM) <{POST_SNAPBACK}>
Hi All,
Yah... I found the SC's attitude is cincai only, they only look into it if you specify the problem and tell them how to check or fix it. I have the same problem with the SC before until I consult the usual workshop from outside, then just tell the SC on what the outside workshop says, then they only know how to do.
sugen
Posted 16 March 2011 - 05:54 PM
sugen
  • 918 posts
My 17 months old Rondo Battery die off 2 months ago.. It clocks at 52k KM... No symtom at all, suddently can't start.. I change to NS70. A bigger capacity's battery.. The stock battery brand is " WATA"..
jason81
Posted 17 March 2011 - 01:08 PM
jason81
  • 56 posts
QUOTE (buckeyes @ Mar 14 2011, 02:19 AM) <{POST_SNAPBACK}>
if the battery is ok , try check if there is leakage in circuit , example a fault break switch which make the break lamp on after u off the car may cause the problem ...
normally a battery warranty is 1 years .. if the naza don wan change for u ..try go to the other autorizhed SC ..they may be easier to kao tim
arch747
Posted 20 March 2011 - 01:42 PM
arch747
  • 97 posts
QUOTE (sugen @ Mar 16 2011, 05:54 PM) <{POST_SNAPBACK}>
wouldn't it give some kind of signs such as difficult to start (takes couple of key twisting before the engine can be on)..? My experience with batteries for the last 3 cars were all like that.
how much does it cost your new battery?
sugen
Posted 21 March 2011 - 10:26 AM
sugen
  • 918 posts
GP NS70 RM 270..
QUOTE (arch747 @ Mar 20 2011, 01:42 PM) <{POST_SNAPBACK}>
