alankkwong
Posted 09 July 2010 - 08:04 AM
Alan,
For the charger, which one you get? 4.5A,8.0 A or 10 A? Interested to get one also. This desulfator is permanent fix to the battery or just temporary during desulfation only?
I got the 12A charger. You can permanently fix the desulfator but I just use it temporary so that I can switch between my other vehicles at home...
Its not what you have...... its how you use it!!
Lechuck
Posted 09 July 2010 - 09:24 AM
Just the desulfator fixed in your car permanently is sufficient. The reason I got a charger is because I am away from home for weeks and don't even start my car.
I see..I do have an electricity driven battery charger at home so i guess the portable charger is not necessary...did you get the 12v or 24v desulfator?
alankkwong
Posted 09 July 2010 - 09:52 AM
of course 12v laaa
Lechuck
Posted 09 July 2010 - 11:06 AM
of course 12v laaa
okay..
benfoo
Posted 09 July 2010 - 11:24 AM
@alan:
bro this is quoted directly from your blog - "
Then, I found an engine mount to touch the negative side since the negative side of the battery is hidden. I saw the green LED light up, that means its working. I am supposed to leave it there for 8 hours."
i spoke to a Mr Martin at the local contact number listed on their website and he mentioned that the negative terminal needs to be connected to the corresponding negative terminal of the battery....it wont work if connected to the body of the vehicle.....
perhaps u shud try locating the hidden negative terminal on the batt bro.....then let us know how to access it......
cheers and haf a swell weekend......
Update: Cross out that query...Martin answered directly to the blog and indicated that it will work, provided the negative terminal is connected as close as possible to the body of the engine nearest to the battery.....
benfoo
Posted 09 July 2010 - 03:04 PM
news does travel fast in cyberworld.....
http://www.infinitum...attery-failure/
alankkwong
Posted 09 July 2010 - 04:00 PM
http://www.infinitum...attery-failure/wow... so fast??
Posted 09 July 2010 - 04:29 PM
wow... so fast??
... when u buy alan .. how come so fast ...
Lechuck
Posted 09 July 2010 - 05:17 PM
i am planning to get one...group buy?
joelucas91
Posted 09 July 2010 - 05:43 PM
