Order & Payment Deadline - 01 May 2011
Order Collection - 07 May Group Lunch 2011
Package 1 - RM280.00
i. Engine Oil Titan HPE Ultra 15W40 - 18 litre pack (sufficient for 2 change interval)
ii. Bosh Oil Filter - 2X (sufficient for 2 change interval)
Recommended Change Interval - 5,000km ~ 10,000km depending on driving condition.
Super High Performance Diesel Engine Oil for the most demanding requirement.
TITAN HPE ULTRA 15W40 is a long-life all season SHPD universal engine oil for high performance engines requiring the latest API performance in combination with top-tier ACEA specifications.
Specifications:
â��€�š API CI-4/CH-4/CG-4/SL
â��€�š ACEA E5/E3/B4/A2
â��€�š GLOBAL DHD-1
â��€�š MB 228.3/229.1
â��€�š MAN 3275
â��€�š VOLVO VDS-3
â��€�š CUMMINS 20078
â��€�š Mack EO-M+
â��€�š MTU Oil Category 2
â��€�š RVI RLD
â��€�š CAT ECF-1
Benefits:
��€š· Long-life SHPD oil has ample reserves to cope with extended oil change intervals.
��€š· Enhanced anti-wear characteristics.
��€š· Provides effective protection against piston ring wear, rust and bearing corrosion.
��€š· Optimised cold start and fast warm-up.
��€š· Good oxidation resistance and reduced varnish, lacquer, sludge and carbon deposit formation even in severe service operation.
��€š· High lubrication oil film strength protects heavily loaded valve train gears.
��€š· Protect against bore polishing, scuffing and minimizes cylinder liner wear.
��€š· Excellent dispersancy retains soot and harmful oxidized products in suspension, aids filterability.
��€š· Good reserve alkalinity retention effectively neutralizes harmful acidic combustion contaminants and prevents premature wear in pro-longed oil service interval.
��€š· Good viscosity-temperature behaviour due to stay in grade characteristics even in very severe conditions.
Application:
��€š· TITAN HPE ULTRA 15W40 is recommended for major US, European and Japanese diesel engines such as Caterpillar, Cummins, Detroit Diesel Allison, Volvo, MAN B&W, MTU, Duetz, W��’¤rtsil��’¤, MB, Komatsu, Hino and others.
��€š· Developed for highly stressed normally aspirated and turbocharged diesel engines with exhaust gas recirculation (ERG) system.
��€š· Ideal all-season oil for mixed fleets, construction and earth moving equipment, marine ferries and industrial equipment with diesel engines.
��€š· Can be used in gasoline engines requiring API SL engine oils.
Package 2 - RM550.00
ATF Oil FUCHS Titan 3353 (as specified in spec) - 1 litre bottle X 9 bottle = 9 litre for full flushing or 2 drain off.
Malee Germany ATF Filter with Gasket - 1pcs
Recommended change interval - 60,000 km.
Order List
1. BK4t9 - 4 Bosh Oil Filter - $96 - Paid $96
2.
3.
4.
5.
6.
7.
8.
9.
10.
Total Order = $96
Payment Paid =
Anyone who interested, please indicate the package ordered and payment instruction will be sent via PM.
May 2011 Group Buy Engine Oil & Atf Oil
r3xt0n
, Apr 22 2011 11:15 PM, No replies to this topic
