tyre pressure at 29 to 30psi???? for your 2 tons monster SUV???
what tyre you use, I remember you use Michellin?
I am using Michelin Latitude Tour H/P 255/65/R16. Rexton Owner Manual do specify 29PSI.
What is your tyre size? If you are using the recommended tyre size to spec, you should follow its recommended pressure as well.
Do note that each petrol station PSI reading may not be 100% accurate. Some bros tested that there is a difference as much as 3 PSI between petrol station pump and actual pressure gauge check. I just pumped nitrogen at 30PSI (measured by 2 different type of pressure gauge by the tyre shop) but it is harder and bumpy than my usual 215kpa (31.2 PSI) at petrol station.
Just checked that those common a pressure gauge having accuracies of +/- 3 PSI, maybe should get a digital one that should be more accurate.
A better way is Flour Test as follows
i. Spread Flour of about 3mm thick on a flat floor in front of a tire covering the full width of the tire
ii. Slowly drive the tire straight through the flour
iii. Analyze the pattern. It will be easy to tell where the most pressure is.
iv. If there is more pressure in the center...decrease your tire pressure.
v. If there is more pressure on the outsides...increase your tire pressure.
vi. Repeat this procedure until you get even pressure across the full width of the tire.
P/S - for msia local, indo, phil & thai tyres it is advicesable to keep to the manuf's recommended psi or check on the side wall their max psi it can hold! Dont push to the extreme max limit.
I tried 230kpa (33.3 PSI) as recommended by the tyre shop but found it too bouncy. I think it is safer to follow the car manufacturer spec than the tyre shop because each vehicle weight and suspension system is different.
