Any one can recommend a good turbo timer for Diesel car?
I have a 2.2 CRDI santa fe, do you think i need one turbo timer?
Turbo Timer
bteong0
, Mar 25 2011 09:46 AM, 6 replies to this topic
Posted 25 March 2011 - 10:02 AM
my family has a triton, and we did not use turbo timer on it, I don't really think we need a turbo timer although our engine is turbo-charged. Adding a turbo timer might prolonger the engine lifespan...
I think any chapalang turbo timer will do, last time bought a RM90 turbo timer on a N/A car for fun haha
Posted 25 March 2011 - 10:25 PM
i think ur santa FE still under waranty? if putting a Turbo timer worry u will void ur warranty, better check with ur SC before adding something on it, since they will cut some cable on ur ignition to connect with Turbo Timer. U can always manually do a turbo timer , before reach destination about 2-5Km, lightly press on thottle, this way also will cold down ur turbo. Just my 2cents
Posted 28 March 2011 - 12:04 PM
QUOTE (forgoodd @ Mar 25 2011, 10:25 PM) <{POST_SNAPBACK}>
Opening the throttle is to prevent from overheating. Is a quick cooling process and instantly expose the turbo to room temperature. (imagine you dip a very hot metal into a bucket of water).
Turbotimer is to delay the engine shut down, and pro-long the cooling process to reach room temperature. (slower cooling process).
Posted 28 March 2011 - 04:40 PM
QUOTE (bteong0 @ Mar 25 2011, 09:46 AM) <{POST_SNAPBACK}>
I don't think you need one coz the engine already comes without turbo-timer... unless you modified and increase the boost..
I'm not sure about this but maybe your engine is already fitted with oil cooler.. dismissing the need for timer..
Posted 31 March 2011 - 10:59 AM
QUOTE (mangojuice @ Mar 25 2011, 10:02 AM) <{POST_SNAPBACK}>
May I know how long do you have the Triton to make that statement?
I prefers to use my head than follow the crowd. After all, it is my money and not theirs.
Posted 03 July 2011 - 02:22 PM
I hv 2.5CRDI Sorento with turbo timer installed by manufacturer. The car did put sticker on driver door to mention if you car drive >80km/hr for long hour need to idle for 1-2minute b4 turn off the engine to let turbo de-energized. If u don't hv timer yourself can be timer by let engine run idle for a while b4 stop.
