Performance Turbo Vacuum Hose
r3xt0n
Posted 18 March 2011 - 11:27 PM
r3xt0n
  • 5,148 posts
QUOTE (spacebar @ Mar 18 2011, 10:55 PM) <{POST_SNAPBACK}>
so my total is RM75 + RM80 = 155 ?
if those injectors burst than got a better reason to change lo , haha
Yes, RM75 for Coolant Sensor that I will collect from Bro ByeBye2U tomorrow. RM80 for Performance Vacuum Turbo Hose to be collected during Group Lunch on 09 April.
byebye2u
Posted 18 March 2011 - 11:29 PM
byebye2u
  • 2,805 posts
coming TT I want to test drive your car.
errierext
Posted 22 March 2011 - 09:21 AM
errierext
  • 288 posts
Count me in for the TVH.....
r3xt0n
Posted 22 March 2011 - 04:52 PM
r3xt0n
  • 5,148 posts
QUOTE (errierext @ Mar 22 2011, 09:21 AM) <{POST_SNAPBACK}>
Added you to Order List, will PM you the account for payment shortly.
rex4585
Posted 22 March 2011 - 08:26 PM
rex4585
  • 681 posts
QUOTE (r3xt0n @ Mar 18 2011, 11:27 PM) <{POST_SNAPBACK}>
Bro Spacebar why need to change the coolant sensor?
r3xt0n
Posted 22 March 2011 - 10:25 PM
r3xt0n
  • 5,148 posts
QUOTE (rex4585 @ Mar 22 2011, 08:26 PM) <{POST_SNAPBACK}>
On his way back from Tmn Negara, sudden water temperature drop to zero, aircon cut and follow by Check Engine light up. Scan error code shows coolant sensor malfunction. So, since have the coolant sensor ready, so replaced it.
rx270xdi
Posted 22 March 2011 - 11:12 PM
rx270xdi
  • 765 posts
QUOTE (r3xt0n @ Mar 22 2011, 10:25 PM) <{POST_SNAPBACK}>
Bro, My advice, don't change it, after change it will still the same. My is just happen last two days...
rex4585
rex4585
  • 681 posts
Bro I had the same problem and changed my coolant sensor. But problem remains. After VFC changed problem solved. Posted this earlier under jammed viscous fan coupling. Check whether VFC is tight.
r3xt0n
Posted 22 March 2011 - 11:20 PM
r3xt0n
  • 5,148 posts
QUOTE (rex4585 @ Mar 22 2011, 11:12 PM) <{POST_SNAPBACK}>
Yes, Bro Spacebar VFC also quite tight. Already given my VFC to the workshop to try servicing. If good, then Bro Spacebar can try too.
QUOTE (rx270xdi @ Mar 22 2011, 11:12 PM) <{POST_SNAPBACK}>
Already changed, too late. hahahaha
rx270xdi
Posted 22 March 2011 - 11:39 PM
rx270xdi
  • 765 posts
Actually Merc engine needed higher temp for better running.
