#61
adrwoon
Posted 21 March 2011 - 10:17 PM
Hi Andy,
Appreciated your enthusiasm for making our sonata looks more pretty. I also just purchased the DRL.
1) the fusebox in your diagram is the box under the steering??
2) Tap a wire from the (cigarette lighter) ground point and connect to the both red wire of the harness?
Thanks for your help
hi
blcw1208.. 1) the fusebox is the one in the engine bay..
2) tap a wire from one of the fuses in the fuse box to the red wire only connected to the small harness that I drew.. i'll check on whether the ground is really necessary as the harness is connected to the parking/high beam connectors which should be grounded...
btw, it's Adrian
I don't want to be a genius - I have enough problems just trying to be a man.
Albert Camus
#62
blcw1208
Posted 21 March 2011 - 10:56 PM
blcw1208
hi
btw, it's Adrian My apology, Adrian. Btw, I'm Brandon.
2) So, u tap the power the fusebox. Thus, the DRL is protected by the cigarette light fuse?
My DRL dont have the small relay as I requested SR to remove the signal turn function. Is it ok?
TQ
#63
adrwoon
Posted 21 March 2011 - 11:13 PM
TQ
hi
Brandon... if the small relay is removed, then the DRLs don't have to run off harness that Shark Racing provided.. If you want the DRLs to be on on ACC, then you just need to pull wiring from the fusebox direct to the DRLs.. any competent accessories shop would be able to lay the wiring for you in that case...
Albert Camus
#64
MOUSEY
Posted 22 March 2011 - 07:54 PM
I'm tempted to get me one of these.
http://cgi.ebay.com/...=item4154855353and
http://cgi.ebay.com/...sQ5fAccessoriesI'm just wondering if it's always the case we need to import in or are there any local dealers who actually supply it ?
Some drivers drive crazily or drives you crazy
#65
scann69
Posted 01 April 2011 - 12:16 AM
scann69
Driver
Anybody interested to go to Puchong tomorrow (Friday) to check out some accessories for the Sonata? I've heard of you guys talking about this shop in Puchong but till now have no idea where is the shop. Am hoping somebody would give me the address so i can use my GPS
Not sure if i'm getting anything yet but would be great to meet up with some other Sonata owners to see what i can add to my ride
Anybody?? Maybe a small Teh Tarik session
Say around 2pm?
Posted 01 April 2011 - 12:49 AM
Anybody interested to go to Puchong tomorrow to check out some accessories for the Sonata? I've heard of you guys talking about this shop in Puchong but till now have no idea where is the shop. Am hoping somebody would give me the address so i can use my GPS
Say around 2pm?
hi,....do u mean friday or saturday????if saturday..i'm fine...can provide shop address......
#67
scann69
Posted 01 April 2011 - 12:57 AM
scann69
Driver
My bad...Friday 2pm
#68
adrwoon
Posted 01 April 2011 - 08:48 AM
for now, it's a bit hard to source for locally manufactured bits and pieces.. apart from the two body kit retailers/manufacturers listed somewhere in this forum, accessories for the time being will have to be sourced overseas...
but i'm sure, there'll come a time when it'll be manufactured here at home
Albert Camus
#69
adrwoon
Posted 01 April 2011 - 09:38 AM
My bad...Friday 2pm
unfortunately, i can't make it @ 2pm.. but, i will be heading there later in the evening - say around 6:30pm...
Albert Camus
#70
scann69
Posted 01 April 2011 - 09:41 AM
scann69
Driver
Ahhh....6.30pm kinda late for me. Nevermind then....another time
