I am having problesm opening both teh side sliding door. The engagement
lock appers to be stuck or not connected to the lever outside the door. I
have to push the door forward (door in closed position) then try to snap
the lever quickly to open the door. This seems to work so far but its a
nuisance. Sometime, even opening from inside the vehicle also cannot. The
lever moves but the lock is no disengage as though its locked. Does anyone
here have similar problems with this? I hope you can share your
experiences. Thanks.
Ulysse '01 Auto
Ulysse manual sliding door
bm_dp
, Feb 20 2008 01:21 PM, 3 replies to this topic
Posted 23 June 2008 - 06:10 PM
Its OK after send it to my friend mechanic who then just spray some
lubricant to teh locking mechanism. Seems to be holding quite well so far.
So I guess the problem is solved .... for now...
Posted 23 June 2008 - 09:07 PM
u r very2 lucky le bm_dp.
mine ,,,,,the steel that is attached to the knob is broken into 2.
ask for lathe the same pattern but it cost me bout rm100.though look simple
but its complicated too.
i now send it to lumut to lathe or to weld it.
it will take me a week or so .
so for others ...do rajin2 put sort of lubricant .
