COMPREHENSIVE REVIEW: Toyota Altezza AS200 (Lexus IS200)/ RS200 BEAMS DUAL VVTI
The Car - Wheels/tyres
LEXUS says the tyre choice for the IS200 was specifically developed to match local conditions and driving tastes. So what do we get? Quite a choice actually. While the standard offering is a 16-inch x 6.5-inch alloy wheel mated to the 205/55R16 V-rated Bridgestone RE030, the Luxury Option offers a machine-finished 17-inch x 7-inch alloy wheel combined with a 215/45 17R Z-speed rated Bridgestone RE040. Two accessory 17-inch wheels are offered: one from Japan the other from OZ Racing in Italy.
The Car - Luggage
THERE'S no split-fold rear seat, but there is a "Trunk-through" capacity which adds to the IS200's flexibility. A sports ski port bag, which can hold four snow skis or two snowboards, is an accessory. A safety triangle and a comprehensive first-aid kit are located in the boot. The kit includes items for communicable disease protection. There are chromed luggage tie-down hooks in the boot.
The Car - Stand out features
THE IS200 reeks of individuality, thanks to its bespoke exterior and interior, including the striking chronograph instruments. The performance of the chassis is outstanding, backing up the sports look, and the gearbox is exceptional. Its equipment levels are high and the pricing is attractive. There are also plenty of options and accessories to customise your car.
The Car - Climate control
CLIMATE control air-conditioning is standard in the IS200, and includes a pollen filter which keeps pollutants to a minimum.
Rotary type heater/air-conditioning controls are used. There are also rear seat passenger ventilation ducts. An external ambient temperature gauge is part of the package.
STEERING:
* Power-assisted rack and pinion
* Turns lock to lock: 3.25
* Turning circle: 10.2m
BRAKES:
*Vacuum-boosted dual circuit hydraulic with four-wheel discs.
*Front brake: 296mm x 32mm ventilated discs with twin-piston, floating callipers.
*Rear brake: 307mm x 12mm solid rear discs with single opposed piston callipers.
*Anti-lock braking system: four-sensor, three-channel type.
*TCS (Traction Control)
DIMENSIONS:
*Length 4400 mm
*Ground clearance 150 mm
*Width 1725 mm
*Height 1420 mm
*Total (curb) weight 1360 kg / 2998 lb
*Wheelbase 2670 mm
*Track front 1495 mm
*Track rear 1475 mm
AVERAGE FUEL CONSUMPTION:
1) FC: 11.6km/l
2) FC: 11.0km/l
*Fuel tank: 60L
PERFORMANCE:
1)* Top speed: 215km/h (Top speed: 207km/h - Auto)
*0-100km/h: 8.5 secs (11.2 secs Auto)
2) *Top speed 233km/h if unrestricted (JDM limited to 180km/h)
0-100km/h: 7.2 secs (MANUAL)
*Top speed 230km/h if unrestricted (JDM limited to 180km/h)
0-100km/h: 8.0secs (AUTO)
