Auto Transmission : Engine Braking Vs Brakes
bigal26
, May 29 2010 08:04 AM, 186 replies to this topic
Posted 29 May 2010 - 08:04 AM
Hi Guys
I've been driving an auto car for many years now and I find that i'm very used to stepping on the brakes to slow down. I know that we can slow down by down shifting the gear. Will this have any effect on the gearbox? Which is better to do?
Posted 29 May 2010 - 12:08 PM
It depends on the situation. For example, if you're stopping for a traffic light or jam, the answer is simply to use the brakes to slow the car down.
However, if you're descending a slope and want to keep your speed in check, you should definitely use engine braking. If you use your brakes to slow the car down, the generated heat will boil the brake fluid and also reduce the effectiveness of your pads, causing a loss in braking performance.
Posted 29 May 2010 - 09:26 PM
QUOTE (TheGunner @ May 29 2010, 12:08 PM) <{POST_SNAPBACK}>
The strage thing is if I go to Genting, I will always upshift or downshift to slow down. But in town on flat road, I don't. I'f I'm running fast on a straight and I see a car ahead, I tend to brake and not downshift. So what you say is at all times (of course not at trafffic lights), its better to downshift? Does that do any harm to the engine?
Posted 30 May 2010 - 12:31 AM
QUOTE (bigal26 @ May 29 2010, 09:26 PM) <{POST_SNAPBACK}>
Err... my statement did mean that for town driving purposes, you can just go ahead and use the brakes.
Posted 30 May 2010 - 08:40 AM
QUOTE (TheGunner @ May 30 2010, 12:31 AM) <{POST_SNAPBACK}>
Bro Gunner
What I mean is for town driving or highway, will it do any harm to downshift to slow down (of course not until you hit the car in front
The reason I ask is my car has ETC which is "slope-sensing" so it knows to shift gears by itself. When on straights, it has no idea of what's in front, so it sticks to the highest gear until I brake. When doing that and re-accelerating, the pickup seems slower because of the gear change. Will downshifing, manually bring it closer to the right gear for it to better pickup again?
Posted 30 May 2010 - 09:59 AM
QUOTE (bigal26 @ May 30 2010, 08:40 AM) <{POST_SNAPBACK}>
Bro Gunner
Well... I do use engine braking to slow down for corners as well. As long as you downshift to the right gear, you'll be fine.
Posted 30 May 2010 - 03:05 PM
QUOTE (bigal26 @ May 29 2010, 08:04 AM) <{POST_SNAPBACK}>
Hi Guys
Hi there,
FYI, modern autobox will downshift to aid braking.
Even a Proton has this in the Waja 1.8.Its called fuzzy logic.Different automaker has a different names.
This way,the car is always ready to accelerate.
The herder u brake,the earlier it downshift.
Older autobox dont have this feature so its always in the wrong gear when we step on the gas again.
Whenever i drives a manual,i will only uses engine braking when its needed.
Posted 30 May 2010 - 03:28 PM
QUOTE (Gunnerzz @ May 30 2010, 03:05 PM) <{POST_SNAPBACK}>
Hi there,
Hi Bro Gunnerzz
Many Gunner's here..
Yes the auto downshift will happen when I brake but when this happens, it takes a bit of time to shift up again if I accelerate immediately. Say I go from 100 to 40 using brakes vs manually downshifting from 4-3-2, which will respond faster when i re-accelerate again?
Posted 30 May 2010 - 06:43 PM
QUOTE (kohf1drive @ May 30 2010, 06:02 PM) <{POST_SNAPBACK}>
I feel better traction at lower gear
So manual downshift gives better "engine traction"?
