308 Thp Turbo Maintenance
Posted 16 June 2009 - 08:23 PM
It is said that a Turbo Timer will do the job to cool down the turbo even after we switch off the engine. Does 308 THP have a turbo timer built in?
If I'm not mistaken, after a long hard drive, after switching off the engine, I can hear something like a fan is still running. It should function to cool down the turbo right? If not, what's the best practise to cool down the turbo?
Posted 16 June 2009 - 09:56 PM
What you read applies to Japanese Turbo cars. The 308 doesn't need a turbo timer.
It has a water pump for the intercooler that detects the temperature of the engine when you shut it. If its hot, the water pump will continue to let the water flow and cool the engine/intercooler. Also, if its too hot, the fan will continue running.
This is the latest technology in Europe where the Japanese still need the turbo timer... Turbo timers are the thing of the past!
Posted 16 June 2009 - 10:22 PM
Thanks for clarification
Posted 16 June 2009 - 11:55 PM
Alan,
I do understand that the water pump is on demand from ECU but one of the main purpose of Turbo timer is to get the Engine oil flowing on the turbine bearing..So, the water pump and fan is for the water to flow through the radiator to cool down the engine and I think it is still advisable to let the engine run for 15-30 secs to let engine oil flow through the turbine bearing..
In this case, if the engine oil pump is on demand from ECU, then it can be just off right away since the oil pump will still pump engine oil through the turbine bearing when it is too hot...
My 2 cents oniiii...
Cheers
Posted 17 June 2009 - 10:53 AM
Cheers
Chargerguy,
From what I've been reading, the new PUG/Mini engines uses both oil and water for cooling. When the engine is shut off, an auxillary electric pump continues to circulate water and cool the turbo.
seriously though...modern turbo's are oil-cooled and as said above, there's no need for a turbo timer to run the car after driving it to keep things circulating. Excessive heat is death for a turbo....manufacturers know this and have designed the cooling systems to properly cool the turbo down with the ignition off.
Don't you think BMW/Peugeot have thought about this problem?
Posted 17 June 2009 - 10:36 PM
Sometimes when the temp is too hot and the engine oil in between the turbine shaft unable to dissipate heat and circulate it fast enuff, it might fry it. This is just my opinion and my practice when dealing with turbocharged car..
Nowadays, I let the engine to idle for like 10-15secs on Prado Diesel after some long journey drive..I did not install any turbo timer or so, just switch off the car later..
Cheers
Posted 18 June 2009 - 12:11 AM
Cheers
Bro, its good practice if you are skeptical. No harm if you let the engine run a while before shutting it off. However, as much as we all love our PUGS, I would believe you don't need to do so. That would be my practice. But, seriously, if you wanna let the engine run for a little while longer... you are right too...
Posted 17 July 2009 - 03:04 PM
i intend to go to the pirelli tyre shop nearby SC as suggested by alan after the service for alignment, to get rid of beyonce.
Posted 17 July 2009 - 04:28 PM
i will do my 2500 inspection next week in KS. Plan to change my engine oil n i m using 5/30 Amsoil.
Posted 17 July 2009 - 04:35 PM
hah, in my honest opinion, you don't need to change the oil. Its recommended to change at 10K, however, in certain countries, its recommended to change at 30K. But due to the weather here which is hot, 10K is better.
However, at 2.5K, you don't need to change the oil. But if you feel rich and kiasu (joking ar.. don't angry).... there is no harm by changing the oil & oil filter, although I wouldn't think its necessary as its stipulated in the service recommendation.
