Estima Speakers
Mikeong
, Apr 23 2009 04:54 PM, 12 replies to this topic
Posted 23 April 2009 - 04:54 PM
Hi does anyone know what is the size of the front speakers for Estima ACR 30?Thanks.
Posted 24 April 2009 - 09:05 PM
QUOTE (drexchan @ Apr 24 2009, 07:44 PM) <{POST_SNAPBACK}>
not sure.. but do you mind if i ask why you need to know?
Just want to change them myself.I think its 6" if not mistaken.Original spekers are not to taste.
Posted 24 April 2009 - 10:01 PM
QUOTE (Mikeong @ Apr 24 2009, 09:05 PM) <{POST_SNAPBACK}>
In most of the cases, it's not a straight fit when you swap the factory speaker with an after market one. You either need to customize a spacer/base with MDF, or to use a different screw hole.
Therefore, the size doesn't really matter as long as it's not too different from the factory speaker. What may give you a problem is the magnet and the depth of the basket.
Most factory speaker from Toyota has a space saving basket and magnet. There might not be sufficient space for yor new speaker unless you get the right one.
How bad is the original one to your taste? Do you have an amplifier? Is your HU the standard 2-din?
Posted 25 April 2009 - 05:36 PM
yes most 6.5" speakers will fit......
www.meog.org/forums
malaysia estima owners group
www.meog.org/forums
IASCA Sound Quality Competitions:
[2003 PWTC Amt 600W+ - 2nd]
[2004 JB Pro 0-600W - 1st]
[2005 Sepang Pro 0-600W - 2nd]
[2006 JVC Fun Class Pro- 3rd]
Posted 26 April 2009 - 06:45 PM
QUOTE (drexchan @ Apr 24 2009, 10:01 PM) <{POST_SNAPBACK}>
I'll use a 6" 2 way speakers and reuse the spacer basket just cut the cone and the back web. I think it should fit just fine.Any coment will be most welcomed.Will try it next weekend.
Posted 26 April 2009 - 06:48 PM
QUOTE (Zennn @ Apr 25 2009, 05:36 PM) <{POST_SNAPBACK}>
Bro Zenn if i use the 6.5" will i still need the spacer basket?
www.meog.org/forums
www.meog.org/forums
Posted 27 April 2009 - 03:31 AM
depends on the speaker la, maybe can use back, maybe need to make new one from mdf wood...
Posted 28 April 2009 - 04:46 PM
QUOTE (Zennn @ Apr 27 2009, 03:31 AM) <{POST_SNAPBACK}>
Thanks Zenn.Anyone knows of good and reliable installer near cheras for a 11" tft roof monitor?Thanks
Posted 29 April 2009 - 01:50 PM
please la dont just go to your own area only, go to the shops thats best for your car, somore its an expensive car, surely u want ppl who do good work...
anyway, closest to u would be CV in kuchai lama
