On Wheel balancing for vibrating steering wheel?
mych
, Dec 11 2005 09:47 PM, 14 replies to this topic
Posted 11 December 2005 - 09:47 PM
Today finally managed to find one shop in
Penang Island who has the actual machine to do proper on wheel balancing
for the front tyre.. Owner is a old chinese chap. Quite frendly. Ah Eng.
My old Kancil steering wheel shakes when speeds hit 80km/h and above..
The constant rattle caused major issue on the steering rack. Replaced the
steering rack as the steering feel was no longer tight.
All 4 wheels were first aligned using machine. Then the front 2 were
aligned again when all 4 wheels were installed. Front wheels were jacked
up one side at a time. The jack used had a sensor which is attached to a
wheel spinning unit. Weights that were added during the off wheels were
not touched but other weights were added and readjusted to minimise body
vibrations..
End result: Test run up to 110km/h without feeling any vibrations on the
steering wheel. Cost RM40. Well worth $$ for the time taken and the
results...I must add that not many tyre shops are willing to do on wheel
balancing as it is space and time consuming. This guy has 2 shoplots!
Syarikat Tat Eng Tayar Dan Bateri
422 & 416, Jalan Jelutong, 11600 Penang
Tel: 04-2826306
to expand further:
"The jack used had a sensor which is attached via com cables to a
computerised wheel spinning unit."
The first time I have done on wheel alignment was with my waja in an old
tyre shop in Sepang.. The only difference is that this guy marks the tyre
with a masking tape before the process starts is more accurate placing
the additional weights. It only took him less than 10 mins for 2 wheels.
vibrations..
Tel: 04-2826306
to expand further:
Posted 12 December 2005 - 05:50 PM
So , what are all this do with Volvo ? should post it on
" tire & wheel "section !!!
Posted 12 December 2005 - 10:48 PM
Do you guys have any specific shops in Penang that does suspension tuning
for old Volvo's?
for old Volvo's?
Posted 24 December 2005 - 08:14 AM
If you'll check 'mych" postings elsewhere in the other forums, he just
like to list the technical aspects of the operations. I think his dad just
got a 240/940, so he's quite genuine.
Posted 24 December 2005 - 07:04 PM
Buzzvic,
What's next ? S60T5 or V50 ? How's the V40 BTW ? Better than the 945 ?
Posted 28 December 2005 - 06:25 PM
just sharing some findings.. along the way.. not easy to find tyre shops
willing to do on wheel thesedays, especially in Penang coz got "turned
down" couple of times...
buzzvic,
Thanks for the test drive the other day.. your 945Ts' runs quite well
have fwd the pic to some friends who may be interested as well..
buzzvic,
Posted 29 December 2005 - 10:53 PM
Buzzvic,
You can have it all in the S60-T5 ...
mych,
Why not try Hock Cheong or Keat Cheong or Goh Swee Hin ?
mych,
