940 parts & pricing
Posted 08 February 2005 - 03:49 PM
pocket in the last 4 years as well as from my fellow friends. (Some prices
will differ as those are in 2001).
Please feel free to add new items for the benefits of others.
Absorbers (front) - Sachs 250.00
Absorbers (back) - Sachs Supertouring 160.00
Absorbers (back) - Sachs Advantage 190.00
Absorbers (back) - Sachs Nivomat 800.00
Air filter 60.00
Air-con belt 18.00
Air-con compressor (recon) 750.00
Air-con compressor pulley 230.00
Air-con compressor oil 45.00
Air-con receiver drier 175.00
Air-con exp valve 130.00
ATF 55.00
Anti roll bar bush 40.00
Brake disc (front) 269.00
Brake disc (rear) 400.00 / set
Brake pad (front) 181.00
Brake pad (rear) 140.00
Brake pump 350.00
Bonnet Cable (front) 340.00
Handbrake shoe 160.00
Coil 165.00
Coolant Hose 125.00
ECU 3,500.00
Engine Mounting 170.00
ETC Sensor (Lambda light) 241.00
Exhaust gasket (for manifold) 181.00
Expansion Tank 190.00
Expansion Tank Cap 63.00
Expansion Tank bottom hose 232.50
Fan Belt 55.00
Gear Box Oil Sump Gasket 45.00
Gear Box Oil Sump (OEM) 250.00
Gear Box Dipstick housing (OEM) 160.00
Gear Box Mounting 211.00
Oil filter 35.00
Power Steering Belt 53.00
Radiator (OEM) 845.00
Radiator (Ori) 1,800.00
Radiator top hose 155.00
Servo Pump Hose 98.00
Spark plug 60.00
Steering Pump (Recon) 220.00
Tapper bush 55.00
Timing Belt 128.00
Timing Bearing 88.00
Turbo return pipe O ring 36.00
Turbo pipe gasket 12.00
Wiper Washer Tank Cap 10.00
Wiper Gear 77.00
* price is per pieces/unit unless indicated.
Disclaimer: This is solely based on the price incurred by me and my fellow
friends. I will not be hold responsible of any mis-statement.
Ciao
Posted 08 February 2005 - 04:13 PM
Front Absober sachs RM 175
Rear absorber Bilstein RM 150
Coolant (ori) 1ltr RM 25
U-Joint coupling RM 60
Sump Guard RM 70
Panhard Rod Bush RM 32 (need 4)
Brake Pad Front (ori) RM 175
Now need new fuel pump. THE WIRE BURNT INSIDE HE TANK. Thank GOD nothing
else happen. Anybody know how much the fuel pump cost for 940 LPT. (new or
used)
Posted 08 February 2005 - 09:41 PM
Vol940,
Are you sure about this, I paid RM 1400 at NSS for that, Yonit Trading
sells it for RM 1300. Both are prices for ori.
Posted 08 February 2005 - 10:23 PM
When I called NSS HQ (KL), they quoted RM 500+, and when I went to NSS
Shah Alam (3 months ago), HQ was wrong quoted, and Shah Alam quoted RM
690. No choice, I bought it and installed at USJ7, the mechanic never
touched volvo before, but I guided him step by step and cost me just for
RM80.
BTW, mine has only 1 fuel pump (inside the tank), but some have 2 fuel
pumps, 1 pre-pump inside the tank, and 1 outside the tank. It seems that
yours is a model with 2 pumps ... am I right ? If so, should be what
Yonit Trading Sells (for both pumps).
The ORI is coming from BOSCH (the most Volvo fuel pump) complete with
sock/filter, but with VOLVO Packaging (part number Bosch 0 580 453 037),
FCP Groton USA sell at US$155 for fuel pump and US$6 for sock/filter.
Expansion Tank complete with Cap, at NSS Shah Alam RM 190. (940 LPT)
Posted 09 February 2005 - 10:51 AM
Thats right, mine is the 2 pump type.The pre-pump or in-tank pump is
pricey.
Posted 11 February 2005 - 05:12 PM
Unit Price Amount Workmanship
RM RM RM
1. Oil Sump Gasket (auto) 1pcs 48.00 48.00 40.00
2. Engine Mounting (SWD) 2pcs 220.00 440.00 80.00
3. Gear Box Mounting 1pcs 235.00 235.00 40.00
4. Alternator Belt 1pcs 65.00 65.00 FOC
5. Frt Shock Absorber SACHS 2pcs 240.00 480.00 120.00
6. Absorber Rubber Damper 2pcs 85.00 170.00 -
7. Absorber Dust Cover 2pcs 75.00 150.00 -
8. ATF Dextron III/flush 14lit 25.00 350.00 80.00
9. Wash & Vacuum FOC
10.Service Inspection FOC
TOTAL INVESTMENT RM 2,316.00
Posted 11 February 2005 - 05:25 PM
wrote it but came out awfully. The three figures are suppose to under the
respective headings namely Unit Price, Amount and Workmanship. Hope
they're still useful.
Cheers!
AYMY
Posted 11 February 2005 - 07:40 PM
everything...I will now have to look for all my invoices for when I had
the S80!
Posted 14 February 2005 - 05:45 PM
Problem - started with engine suddenly rev irregularly whether idle or
driving then disappear, then car does not start and Lambda light came on
Airmass sensor Rm 1500
Pick up sensor Rm 215
Coolant temperature sensor Rm 250
Temperature sensor Rm 198
Got AAM to rescue me twice before send to FA.
Izallyza, what was the problem in your case ? what is the ECU that you
paid Rm 3500 for ?
