jeep 2.5L mechanics in PJ
Posted 04 November 2004 - 10:25 AM
May need to get the brake pads change. BTW, anyone knows the cost?
Posted 04 November 2004 - 06:55 PM
reference the pads in my 4.0L cost RM175.
Posted 09 November 2004 - 11:23 AM
wrong with the pads. However, my brake will squeak slightly but
noticeably whenever I press the pedal, any clue what would have gone
wrong?
Posted 10 November 2004 - 08:05 AM
It could just be the dust as they accumulated. If the pad is okay nothing
to worry. I'm sure a litle squeak will not bother you. Let me know if
you found a good and reliable mechanic in PJ.
Posted 12 November 2004 - 04:31 PM
the pads, it's the contact to the pot that is making the noise.
Posted 30 November 2004 - 12:43 PM
for service. Where can I find this guy.
I have just sent mine to Najib and have most of the problems solved.
This guy is not bad and is knowledgeable about jeep. just like to expand
my contact list (for jeep mechanices) in case najib is too busy.
Posted 13 December 2004 - 02:43 PM
His workshop now is in Wangsa Maju somewhere (I have not been able to
locate the place - maybe have not try hard enuf). Anyway, his hp is 012
377 5079 (he is very helpful). BTW, where is this Najib guy? Maybe I can
send my Jeep to him as I'm in PJ now. Servicing is due now (overdue
actually). I was told that we can use Volvo oil filter as replacement.
Is this advisable? Someone can comment on this?
Since Jeep owners are getting smaller now, lets keep in touch and continue
using the Jeep. Under the right maintenance I believe Jeep can last.
Posted 14 December 2004 - 02:48 PM
wangsa maju. Najib's contact details are as follows:-
Jip Auto Services
No.67 Blok E2
Jalan 1/18A
Taman Mastiara
Batu 5 Off Jalan Ipoh
Tel:- 019-273 9916
From LDP, go to Jalan Kepong, then take 12 o'clock turn at the roundabout
to enter Jalan Ipoh. turn left on the first traffic light (tire shop at
the left corner) and go straight and you will reach Taman Mastiara at the
end of this road.
Najib is helpful too and he does not might you bring along your own parts
for service/repair.
Posted 16 December 2004 - 05:03 PM
Thanks for the info. Do you know about the Volvo oil filter? I was told
that we can use that as a replacement for the Jeep oil filter. Have you
try that? Where do you get your replacement parts? Last time I got them
from Auto Asli, Jalan Kelang Lama. Try to source from US but was told
that that our Jeep are Europe spec. (that was when I need to replace the
ECU).
Regards,
Posted 17 December 2004 - 02:23 PM
Najib. How much does volvo oil filter cost? Najib charge Mopar oil
filter for RM40 and air filter RM48, still bearable.
Najib will be able to provide part no. for part sourcing. That helps as
the part no. is common across all regions. Am also trying to source
parts from overseas, particular from China as it is cheap there. Have a
cousin to help me in this and will inform you of any progress.
