LCD screen on dashboard dying
Posted 22 November 2004 - 04:04 PM
Wondering whether you guys can help me on this one. The wordings and
letterings on the LCD screen of my A4 1.8T is slowly but surely fading
away.I was told by the guys in AD that this is a common problem due to the
weather here.My A4 is only 3 years old. Is this really a common problem ?
I was told that to replace it will set me back by a couple of grands.Any
solutions here.BTW have received the application form for CAM via mail
from Lau but no details on where to submit.
Posted 22 November 2004 - 05:12 PM
years. Oh yes .. is your car tinted with a v-kool to protect the
dashboard?? Bcoz mine has the v-kool installed.
Posted 22 November 2004 - 05:30 PM
experienced this.
Posted 22 November 2004 - 05:32 PM
Its not a common problem, both my Golfs MFA is running fine one is 19 and
the other is 11yrs respectively. Minne you no Vkool or whatsoever.
Posted 22 November 2004 - 06:29 PM
problems with the MF display in my Passat without any tinting after 4
years.
Posted 22 November 2004 - 10:14 PM
some insulation around the meter cluster?
It may help to reduce the unbearable heat that may have damaged the lcd
panel.
Just a thought.
Posted 23 November 2004 - 11:37 AM
If you're daring enough, you can remove the thing, take it apart and
inspect the contact point between the LCD screen and the circuit board.
Either the thing has lost it's pressure on the contacts or the screen has
died.
Posted 24 November 2004 - 10:32 AM
responses from 7 turbo owners all with the same problem. On whether or
not it's a common problem I don't know, nor do I care, because it is a
problem.
Sorry to say nothing much can be done except buy a new cluster. I've
tried and hit walls after walls. You might want to try too and see if
you're more successful.
Posted 24 November 2004 - 05:59 PM
Hey David,
Can you hand me the disused instrument cluster? I'll see if I can do
something about it.
I'll use the same method I use to repair my LCD display problems on my
mobile phone.. a bit of sandpaper, some good quality cleaning alcohol and
a good deal lots of spare time
:P
